1/2" line should be fine. And mount it however you want and as close or as far from the motor, with that size line (or bigger) you will be just fine. The "euro" style cooler has both lines on the bottom, I had them both on the top when I had the sandwich plate and radiator type cooler, it seems not to matter much, as the air will get pushed out however it is mounted.
