Don't be shy to offer up any trades either... open to all sorts of things
#1
*** Update 9/21: price drop $2200.... "
*** Update 8/28: price drop $2800 obo... Some one button this beast up! ***
*** Update: will consider parting given enough interest ***
1991 jetta zero miles on build... 1.8 16v head on aba bottom end, abf alternator bracket to eliminate AC, Bildon Motorsports drivetrain... basically their "race" package... cams, titanium valve springs etc etc you can check it out online.... has an ebay t3/t4 on it, shopping around for hx35 holset... have everything for the car... just installed Bahn Brenner DP, "The Bomb" SRI, 034 EFI Stage IIC, complete 16vt wiring harness for that... injectors, coils packs, volvo oil cooler, swapped to O2A trans, swapped everything over already, etc etc... drain line and feed line need to be installed, have both, IC and piping need to be run, front driver's brake line needs replacing, everything else that has to do with the brakes has been replaced (calipers, lines, prop valve, disks, pads, new wheel bearings front and back, ball joints, tie rods blah blah blah)... you name it its probably been done. basically it's at the 99% point and just needs the little stuff wrapped up. My issue is that the car is in NY, I live in CT, and my new life schedule allots me zero time to tinker with it and I don't want it sitting any longer to the point it's useless... the body is in good shape, front fender markers shaved, all surface rust/dings/dents were removed and a fresh coat of alpine white was put on there... rear VW was poorly shaved and it's starting to pop out a little.... have a full brown/tweed interior, small bumpers, gli spoiler, no flares, early gli door trim, no plate tub... basically building a sleeper... anyways let me know if you have any questions... have a bunch of pics on my phone and I probably forgot a lot of stuff.... please don't let this car become a lawn ornament... 518-929-3339
Quick list of the engine/trans crap
8 to 1 compression ratio
252°/264° bildon camshafts
16v race valve train from bildon motorsports
abf forged wossner pistons
abf forged wossner rods
new oil jets
short runner intake
BBM turbo manifold
t3t4 50 trim turbo
custom fuel rail
adjustable light weight cam gear
light weight im shaft sprocket
new bearings and all seals
6 puck stage 3 clutch kit
BBM solid front motor mount
vf engineering poly trany mount
oem rear engine mount new
Will not be offended by offers
Thanks,
Erick
#2
#3
Don't be shy to post pics of your car.![]()
#4
Haha touché... I'm down working in Florida, good pictures on my computer back home in CT... I have some on my phone I'll work on loading up...
#5
Can't upload onto photobucket from my iPhone... More than willing to text/email pictures
#6
#7
Against that some chit.... Shoulda known... Also have red stripe smalls to match the door trim... D90's not included... Probably getting put on my 911
Right after paint
#12
Bump... Update added... With enough interest I'll start parting her out
#14
If you finish it up, sure... Take maybe 2 solid weekends of work
#17
#18
I realize this, if I had it running I wouldn't be letting it go... But I'm 150 miles from the car, am not able to regularly make that trip, and may be tranferring to Munich for work... So my priorities have shifted a bit... Open to reasonable offers, not looking to clear project costs as its not my first rodeo and I know that's impossible, just want the car and/or parts to go to good use... So far clutch has been spoken for, and there's been interest in the motor
#20
extremaly interested in the head possibly long block as a whole
my build thread pic heavy http://forums.vwvortex.com/showthrea...k-build-therad click for corrado bently PDFhttp://www.4shared.com/zip/eVgLVViZ/corrado.html
#21
Ttt not really looking to part, not enough interest at this time
#28
Ttt anyone? Price reduced... About as far as I can/wanna go... $2300.... Let's talk people...
#29
How does it sit now? I wld prolly be in with the D90's
Run Your Car, Not Your Mouth!!!
http://forums.vwvortex.com/showthrea...t-on-Camera...
#30
Shell is gone, but no... The D90's are slated for my 911... Just had em on for rollers
#31
if the shell is gone whats left
#33
im really interested in the head but how much for the whole long block
#34
Actually let's talk about all it as a lot. I.have a project in.mind. pm.or email me. Ewillard89@gmail.com
