VWVortex.com - Sunroof Question..
    Results 1 to 8 of 8
    Thread: Sunroof Question..
    1. 08-06-2012 06:57 PM #1
      Does anyone know how interchangeable the sunroof from an 86 Golf would work on an 88 Scirocco? Im talking the inside track and everything...
      Anyone
      "Reasonable people adapt themselves to the world. Unreasonable people attempt to adapt the world to themselves. All progress, therefore, depends on unreasonable people."
      -George Bernard Shaw
    2. Member crazyaboutrocs's Avatar
      Nov 23rd, 2005
      Winterport, ME
      2 '88 Sciroccos and an '08 MkV GTI
      08-06-2012 07:21 PM #2
      I never knew anything was interchangeable, but recently have read of a few people using the parts from Golfs/Jettas. You will not have the tilt option though, if you go this route.
    3. 08-06-2012 07:25 PM #3
      Quote Originally Posted by crazyaboutrocs View Post
      Ok cool. I dont mind about the tilt option. Open or closed is fine with me. This Sunroof "project" has been nagging at me waaaaay too long.
    4. Member 86rocco8v's Avatar
      Mar 26th, 2007
      1986 Scirocco 1.6td. 1992 Jetta coupe 1.6td
      08-06-2012 08:35 PM #4
      Golf/Jetta works.....the tilt is gone but you have to run the sunroof panel from the donor car. the bolt holes do not line up with the Scirocco panel....paint to match
    5. Member ANSAracingb's Avatar
      Aug 16th, 2005
      Gilroy CA
      '90 VW Jetta GL, '90 Jeep Comanche, '16 BMW F800GS
      08-06-2012 08:56 PM #5
      I'm one of the people who did this recently.
      Make sure you also get the interior cloth panel, too. It's a very easy swap, only takes about 1/2 hour to do the whole job. Once you are done installing the A2 setup into your s-rocc remember you may need to adjust the height adjuster screws.
      -Bryan
    6. Member vwdaun's Avatar
      Oct 6th, 2001
      Dayton OH
      Multiple Sciroccos and a Jetta Wagon
      08-07-2012 02:11 AM #6
      Why would anyone do this? I couldn't live without the tilt feature.
    7. Member ziggirocco's Avatar
      Dec 13th, 2010
      Montreal
      1987 16v scirocco
      08-07-2012 08:32 AM #7
      Quote Originally Posted by vwdaun View Post
      If your sunroof assembly is screwed up and you cannot find another Rocco assembly, then the Jetta/golf roofs are more common and easier to find in most areas.
      Old sciroccos never die....they just go faster....sometimes.......
      www.ziggituning.com
      My Project...
    8. 08-07-2012 08:56 AM #8
      Seriously? You would DIE without it?
      Haha
      Ok thanks everyone. I was wondering if i needed that panel as well, now i know.
