Results 1 to 3 of 3
Thread: sad sad sad
  1. Member bluewolf2001's Avatar
    Aug 24th, 2011
    cincinnati, ohio
    2001 wolfsburg jetta, audi a4 2.8 avant
    08-06-2012 08:03 PM #1
    so my cars has been running like hell, it doesnt hardly idle. i cleaned the throttle body and maf sensor. now my throttle doesnt even do anything when i push the peddle. My buddy scanned with Vag-com and heres what we came up with.
    ENGINE FAULT CODES:
    Monday,06,August,2012,19:47:45:24333
    VCDS Version: Release 11.11.3 (x64)
    Address 01: Engine Labels: 06A-906-032-AWW.lbl
    Control Module Part Number: 06A 906 032 DL
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 07500
    Work Shop Code: WSC 13879
    VCID: 6BDFD103199ED11
    11 Faults Found:
    16804 - Catalyst System; Bank 1
    P0420 - 35-10 - Efficiency Below Threshold - Intermittent
    17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
    P1171 - 35-10 - - Intermittent
    17950 - Angle Sensor 1 for Throttle Actuator (G187)
    P1542 - 35-10 - Implausible Signal - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - Intermittent
    16685 - Cylinder 1
    P0301 - 35-10 - Misfire Detected - Intermittent
    16687 - Cylinder 3
    P0303 - 35-10 - Misfire Detected - Intermittent
    16688 - Cylinder 4
    P0304 - 35-10 - Misfire Detected - Intermittent
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 - 35-10 - Implausible Signal - Intermittent
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-10 - Signal too Low - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    17976 - Throttle Actuator (J338)
    P1568 - 35-00 - Mechanical Failure
    Readiness: 0000 0000
    ABS System Fault Codes:
    Monday,06,August,2012,19:50:11:24333
    Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
    Control Module Part Number: 1C0 907 379 D
    Component and/or Version: ASR FRONT MK60 0103
    Software Coding: 0018945
    Work Shop Code: WSC 00066 000 00000
    VCID: 2B5F1103891E111
    2 Faults Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    013 - Check DTC Memory
  2. 08-06-2012 08:21 PM #2
    2 threads? Put this in the other one.
  3. 08-06-2012 08:26 PM #3
    Quote Originally Posted by bluewolf2001 View Post
    ENGINE FAULT CODES:
    11 Faults Found:
    16685 - Cylinder 1
    16687 - Cylinder 3
    16688 - Cylinder 4
    2 Faults Found:
    Clear codes, cycle the ignition (on to off and back to on but DO NOT TRY TO START IT), then adapt the throttle body. Cycle the ignition once again (off then on and this time start it). Should clear this up.
    "I am for truth, no matter who tells it. I'm for Justice, no matter who it is for or against. I'm a human being, first and foremost, and as such I'm for whoever and whatever benefits humanity as a whole" - Malcom X
