Results 1 to 10 of 10
Thread: Fuel filter
  1. 08-06-2012 09:32 PM #1
    Where's it at for the 2.0 T? Part number?
    Sent from my DROID RAZR using Tapatalk 2
    Feb 17th, 2008
    brooklyn ny 11230
    07 passat 2.0t wagon,09 vw cc vr6 4motion
    08-06-2012 09:41 PM #2
    in fuel tank
    strictly a lower case poster Mods too many to list
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    08-06-2012 09:42 PM #3
    Its considered a life time filter but its typically sold as on unit with pump. If your parts guy is good he will notice it can be ordered separate now even though originally it wasn't that way.
  4. Member najel's Avatar
    Apr 10th, 2008
    Mankato MN & Bielefeld Germany
    03 Jetta GL & 06 Passat 2.0t
    08-06-2012 10:24 PM #4
    Quote Originally Posted by Boosted2003! View Post
    Do you happen to have any details on that? Part number? How to install? I imagine you still remove the fuel pump, but then separate the filter somehow?
    Owning a VW is like having a hot girlfriend that's mentally unstable
    Mar 10th, 2009
    08-06-2012 10:30 PM #5
    Quote Originally Posted by najel View Post
    I have no parts numbered and never really paid that much attention I was doing it at the dealership. It just unscrews once you remove the pump assembly.
  6. Member jhtopilko's Avatar
    Dec 3rd, 2006
    Edmonton, Alberta
    2009 silver leaf passat wagon
    08-06-2012 11:19 PM #6
    You wouldn't change it unless your in tank fuel pump died. It is a very common setup in the 2000s to current.
    The first line of defense is You. H&R springs Bilstein sports APR stage 1, Magnaflow exhaust.
  7. Member Bill6211789's Avatar
    Dec 11th, 2009
    Clifton Park, NY
    2006 VW BT Passat
    08-06-2012 11:21 PM #7
    like said above its in the tank attached to the LPFP to change it you would need to change the LPFP bc they are one unit.
    Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
  8. 08-07-2012 05:17 PM #8
    OK, guess I won't worry about it then. Interesting that it has the same setup as my Honda motorcycle.
    Mar 10th, 2009
    08-07-2012 11:36 PM #9
    Quote Originally Posted by Bill6211789 View Post
    It changed from my experience back in 2010/2011. When I worked a dealership a LPFP was ordered and it didn't come with a filter. So had to order a filter cause we didn't know one could order it separate a first.
  10. Member Bill6211789's Avatar
    Dec 11th, 2009
    Clifton Park, NY
    2006 VW BT Passat
    08-08-2012 03:18 PM #10
    i misread your first post and didnt see the part about ordering the filter separate, that's good news!
