Originally Posted by
keganater
So I finally figured out when the fuse pops!!! See if you can follow me through this...
When you turn on the A/C, the radiator fan also turns on, (built that way on purpose by volkswagen).
Also, when the engine reaches a hot enough temperature, the fan switch in the radiator turns the fan on.
Both of these functions work for me.... However, if both functions occur, the radiator fan fuse blows. So the fan works for either operation but not at the same time, (ex. trying to run the A/C when the car is hot).
Additionally, the fan makes a nice squeaking noise when it is working.
I'm thinking the fan is just on its last leg and needs to be replaced. Anyone else want to contribute their thoughts???
