Results 1 to 6 of 6
Thread: Should I keep this tire? Size issues?
    Dec 24th, 2011
    Belleair, Florida
    2006 Volkswagen Passat
    08-07-2012 12:51 AM #1
    So, when I bought my set of wheels, they came with 225/45/17's. Three tires were needing to be replaced, and one was brand new. I have since replaced all four tires with 245's, but still have the new 225 tire. My question is, in the event that something happens to one of the 245 tires, can I put the 225 on with minimal problems? The major one I could see would be it spinning faster/slower. Not sure if that is a problem I could have, but looking for someone with more knowledge. Would it be a noticeable difference? Safe or no? Thanks guys!
    2006 Passat FSI 2.0T | Forge DV Spacer | 17" Monte Carlo Wheels | 10" Kicker sub in custom box | iPad Mini Dash installed as headunit | 5% Tint on sides, 30% on back window | Carbon fiber mirrors | Votex Roof Rack | Resonator Delete w/ Magnaflow tips | Badgeless grill | OEM Audi S6 LED DRLs | Lip spoiler
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    08-07-2012 07:26 AM #2
    ...speedometer will read faster
    ...odometer will read faster
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  3. Member Tutti57's Avatar
    Jun 20th, 2011
    Rochester, NY
    2006 Passat 2.0T and 2008 Touareg VR6
    08-07-2012 07:32 AM #3
    Not good if you have 4motion. Do you?
    2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | Rev D Diverter Valve | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
    2008 Touareg VR6
  4. Member
    May 10th, 2010
    North Jersey
    08-07-2012 07:58 AM #4
    Quote Originally Posted by Tutti57 View Post
    he doesn't....he has a 2.0T (it says it in the signature).
    plus, with AWD, it is the differential of front wheel(s) rotation vs. rear wheel(s) rotation that messes with the AWD system.
    Other Rides:
  5. Junior Member
    Apr 27th, 2012
    LI NY
    2008/VW/Passat 2.0t FSI
    08-07-2012 02:52 PM #5
    It shouldn't cause any mechanical problems, it will just make your handling feel a bit odd. Though I wouldn't do it for prolonged use especially in the front, but it will get you by for a while in a pinch.
  6. Member
    Dec 24th, 2011
    Belleair, Florida
    08-07-2012 11:22 PM #6
    Thanks for the replies everyone. As someone said, no 4mo. In the event that this tire was on my car with my three 245's, I'd probably move it to the back so my front wheels have the same tire width. I will look into selling the tire still though, if it is worth enough for it to make sense for me to sell it, I probably will. If not, I'll keep it as a "spare."
