Results 1 to 15 of 15
Thread: no power low end
  1. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    90 rado,92 slc 86 rocco,98 avant
    08-07-2012 09:19 AM #1
    so my old engine crapped out number 3 rod bearing so i bought a used engine, it has good compression looks pretty clean. but after the change it now has no power at the low end rpm's 1000 to 2500 then after seems o.k., has new plugs, wires, filter, it also seems to miss fire, do i need to reset any thing? or do any thing else?
    some day soon the rado will be done
    www.eurowerks.org
  2. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    08-07-2012 02:28 PM #2
    Asides from the miss firing is it using the same trans or a different one from the donor car?
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  3. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-07-2012 02:30 PM #3
    same transmission 5speed, i didn't think i would matter?
    www.eurowerks.org
  4. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    08-07-2012 04:20 PM #4
    No it won't make a difference if it's the same. There are different ring and pinion combos that would make it feel like you lost power.
  5. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-07-2012 04:52 PM #5
    i think i may have figured it out, i forgot to ground the engine i think but the car is at the shop and im at work could that make a difference
    www.eurowerks.org
  6. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    08-07-2012 04:54 PM #6
    depends on which ground but generally missing grounds is not good for anything.
  7. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-07-2012 06:12 PM #7
    i,m thinking it maybe a main one it runs from the firewall to the engine. it is a flat braided one about a 3/4 of a inch wide. ill check it out this weekend and let ya know. if anyone has other tips let me know. thanks for looking
    www.eurowerks.org
    Jan 16th, 2010
    Brantford, Ontario
    2000 Jetta VR6
    08-07-2012 06:23 PM #8
    Check your vacuum(sp?) hoses. I had a similar issue with low end power on a 1.8T AWM engine. Ended up being the fuel pressure regulator vacuum line was ruptured. Caused misfires too and poor idle. Might not be the same line but I would definately check them out to be sure.
    RB
    Jan 16th, 2010
    Brantford, Ontario
    2000 Jetta VR6
    08-07-2012 06:33 PM #9
    Just reading another post and got reminded about something. Is the coil pack good? Maybe swap out your old one if you know it was working and see if it makes a difference. Pretty quick and easy to give it a try.
    RB
  10. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-07-2012 10:28 PM #10
    thanks RB ill look again at the vacume lines and it is dist not coil pack, but good call
    www.eurowerks.org
  11. Member
    Jan 16th, 2010
    Brantford, Ontario
    2000 Jetta VR6
    08-08-2012 06:15 AM #11
    Sorry, should have payed more attention. My VR is a MKIV.
    RB
  12. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-09-2012 12:02 AM #12
    I have one other question my old engine had a egr valve and the new one does not will that make a difference at all .The new engine came with the wire harnessso i just twisted the old harness off at the conector and just plugged it into the car. do i stillneed to unplug #10 pin at the ecu.................
    www.eurowerks.org
  13. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    08-09-2012 01:02 AM #13
    I'd say yes, then you know for sure. (regarding cutting the EGR wire)
    I'd also take the distributor from your old engine and put it on the new one. I had similar issue with a bad "cam position" sensor. It's part of the distributor and can't be bought separately. Or check to make sure you have it plugged in. It hangs pretty much directly below the distributor. Will have to feel for it.. 3 wire plug.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  14. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-09-2012 09:04 AM #14
    i did swap the old one, the salvage yard kept the dist so i had to use mine. i cant wait to get this thing killin honda's again
    www.eurowerks.org
  15. Member STEALTHCORRADO's Avatar
    Oct 14th, 2005
    on the ground
    08-13-2012 11:31 AM #15
    so i hooked the ground back up,cut the egr wire and seems to be alot better than before. i also check the dist cap and rotor and number six is all carboned up so ill try a new cap and see what happens... thanks for all the info to help me get closer to getting it running
    www.eurowerks.org
