VWVortex.com - Need help replacing oil pan gasket on an 81 MK1
    Results 1 to 6 of 6
    Thread: Need help replacing oil pan gasket on an 81 MK1
    1. Junior Member
      Mar 1st, 2010
      Indy
      81 Rabbit diesel/85 MB 300D
      08-07-2012 11:12 AM #1
      I'm replacing a leaking oil pan gasket on my car. I'm done, but for two bolts that I simply can't get back on. They are crammed in next to the bell housing on the tranny, which offsets my socket wrench by about five or ten degrees. This is a real drag. Anybody have a recommendation? Different tool? I've tried the socket adapter that looks like a U joint, but that hasn't helped. I cut a length of plastic hose, jammed the bolt into it to drive it in, and still no luck. There is an offset adapter that looks like some sort of a spring, which allows it to flex. I'll try that next. I may have to resort to a mechanic, if I can't do this myself. I like to fix things myself. See below.
      Have any of you read a book titled: "Shop Class as Soul Craft"? It basically discusses how we just throw stuff away instead of trying to fix it; how we've looked down upon blue collar work, and have gotten rid of most shop classes in US high schools. Some of us need to work with our hands. The author, whose name escapes me, is a vintage motorbike mechanic out of Virginia.
    2. Member yowzaa's Avatar
      Jul 30th, 2007
      Los(t) Angeles
      '07 Audi A3 2.0T || '10 Golf TDI
      08-14-2012 08:17 PM #2
      if the bolt is an allen bolt, like I've seen on my mkv, you should be able to use a ball-tipped allen wrench. They give you about 5deg of tilt.
    3. Junior Member
      Mar 1st, 2010
      Indy
      08-19-2012 10:14 PM #3
      Thanks - unfortunately, they are hex head bolts. The trans. is leaking pretty badly, so I'm just going to take it out. While out I'll have complete access to the two final bolts, but there has to be an easier way than this...
    4. Member cuppie's Avatar
      May 3rd, 2005
      Redford, MI
      88 Scirocco 16v (Wilda); 02 Passat NevarLose wagon; '12 Fusion SEL (wife's.) Past: '86 QSW, '87 Golf
      08-25-2012 12:06 PM #4
      There is:
      1/4" drive 10mm 'short' universal-joint socket. Like this guy.
      It is, quite literally, the only thing that will fit in there.
      - Cup
      '88 Scirocco 16v, 'tastefully' modified.
      Click here for my Cincy pics
      things currently broken (Scirocco): 4
      things currently broken (Passat): 4
    5. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      08-27-2012 12:19 PM #5
      A "wobble" extension will work. It will def have to be of the 1/4" diameter size.
    6. Junior Member
      Mar 1st, 2010
      Indy
      09-30-2012 09:40 AM #6
      thanks for replies. since the trans. was leaking, I removed it, had it resealed, and had access to the two bolts in question. The seals has failed and the clutch disc was black with oil. solved multiple issues.
