Results 1 to 13 of 13
Thread: Another Bilstein coilover question...
  1. Member G60JETGLI's Avatar
    Apr 21st, 2012
    Franklin WI
    GLI's for daysssssss
    08-07-2012 12:50 PM #1
    So I installed my Bilstein PSS coilovers on my coupe quattro today, and I am wondering what people have experienced with settling in. Right now both front and rear are sitting wound all the way down and its basically eliminated wheel gap in the rear and the front has about 10 mm wheel gap still. Im just wondering how drastic the settling in period is because i dont want to be driving one day and then im driving on the fenders
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    08-07-2012 01:08 PM #2
    Settling = myth. Suspension eventually settles, but it's a slow gradual process as the springs and shocks wear over their life. Once it's on the ground, and moved a few feet, or been "jounced" by having your rear end plop into the seat with the ebrake off, it's "settled." Where's Max?
    Can you post some pics? So once the fronts are dialed ALL the way down, the PSS's still don't get rid of tire to fender gap?
  3. Member G60JETGLI's Avatar
    Apr 21st, 2012
    Franklin WI
    08-07-2012 01:18 PM #3
    Ill try to figure out how to post pictures tomorrow...I work thirds ill research how to post pics lol, and there very little gap in the front, car sits perfect right now, just afraid if there was some sort of drop off where one day it settles 2 inches and id be in trouble lol
  4. Member
    May 7th, 2009
    08-07-2012 01:20 PM #4
    You're fine.
  5. Member DougLoBue's Avatar
    Aug 28th, 2009
    Long Island NY
    01' 570awhp TT, 01' B5 A4, 00' TT225 Project
    08-07-2012 02:27 PM #5
    If you have the rear perches in still - remove them. Totally unnecessary.
    bagsarefordeadhookers
    -TCC
  6. Member G60JETGLI's Avatar
    Apr 21st, 2012
    Franklin WI
    08-07-2012 02:39 PM #6
    Quote Originally Posted by DougLoBue View Post
    Rear perches are not my problem...Like i said the rear set with no fender gap and absolutely flush, the front still have minor gap
  7. 08-07-2012 05:10 PM #7
    Quote Originally Posted by G60JETGLI View Post
    20v master is correct, there won't be any significant "settling", what you see is more or less what you'll have.
    Now, the fact that the front is sitting higher (more fender gap) is normal and to be expected. Due to the suspension design and geometry in the front (McCrapson), this is as low as Bilstein felt comfortable allowing you to go without totally butchering the geometry and killing the front end's performance. Personally, I wouldn't even recommend going all the way down with the front, but since that's the look that you're after, I would just raise the rear to to match or simply learn to leave with it.
  8. 08-07-2012 09:11 PM #8
    Quote Originally Posted by Marcus_Aurelius View Post
    What about using the Lupo/Polo strut bushings? They will drop the front about 3/4" and you won't have to spin your fronts down all the way, which can help the ride.
  9. 08-07-2012 09:35 PM #9
    Quote Originally Posted by CubFan63 View Post
    Yes Sir, that's a viable option too, at the expense of some comfort with a bit of increased NVH. With the Lupo mounts, the OP could go a bit lower in the front with the collars all the way down on the coilovers.
  10. Member G60JETGLI's Avatar
    Apr 21st, 2012
    Franklin WI
    08-07-2012 09:58 PM #10
    No worries about the "low". I am not looking to slam my car, I love the way it is riding now and the ride height is perfect the way it is. Like I was saying, as long as this settling in period is a myth, I can relax now because my spacers have the wheels about flush with the fenders. Thanks for the input Ill try to get picks up tomorrow so everyone can observe
  11. 08-08-2012 08:08 AM #11
    I found my suspension settled about .5" within a few weeks. It's not like a 2" settle or anything. But as stated if you want to even it out, just raise the rear up a tad
  12. Member 1.8tipgls's Avatar
    Apr 13th, 2007
    NY
    01' S3, 01' TT 225 roadster w/Hardtop (sold), 03' Jetta (sold)
    08-09-2012 11:02 AM #12
    my car on bilstein pss9 coilovers
    Cult Classic 2012
    DubCult _ Florio Special _ S3
  13. Junior Member
    Apr 16th, 2012
    RVA
    2001 Audi TT Base
    08-09-2012 11:19 AM #13
    Same here i have pss9 installed and I ended up raising the rear to match front fender gap after advised by other members with more knowledge on this subject ..... Thanks Max
    Audi TT 2001 ROADSTER FWD
    BILSTEIN PSS9, DEFCON competition kit, NEUSPEED f/r adjustable anti sway bar, APR stage 1 ecu, APR stage 1 clutch, INJEN cold air intake race series, intake manifold spacer, light weight pulleys, FORGE hybrid DV/BOV, FORGE relocation kit, SPYDER led smoked taillights, smoked side markers
