Please post a complete complete Auto-Scan from a current version of VCDS or VCDS-Lite. -32
Thank you.
#1
heated mirror by THE KILLER RABBIT, on Flickr
i want to disable the heated mirror but i'm not sure how to input the request.
#2
Thank you.
#3
not sure how a scan will help when i took a screen shot of what i would like to change? anyway here one is
Sunday,05,August,2012,01:06:45:08157
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
Mileage: 73340km/45571miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H724V0R8
Coding: 0403010A1C070160
Shop #: WSC 00066 000 00000
VCID: 69F7638C4062C3B
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1816
Revision: 04843012 Serial number: 00000806280685
Coding: 0000020
Shop #: WSC 02069 000 90108
VCID: 130B6164326EA9B
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B600D492600FF880D06E5921A0041B100
VCID: 75CF3FFCDCDA17B
1 Fault Found:
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 73328 km
Time Indication: 0
Freeze Frame:
Count: 17472
Count: 57344
Count: 12800
Count: 125
Count: 46990
Count: 0
Count: 0
Count: 4864
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7CD92AD83FF0463
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001055243
Coding: 04058E2700041500070A00000F000000000859035C00010000 0000000000
Shop #: WSC 00066 123 12345
VCID: 3245C4E0AD34403
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 040908 021 0501
Coding: 00038805
Shop #: WSC 00066
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 106
Reset counter: 57
Mileage: 63806 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.45 V
OFF
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 77
Reset counter: 57
Mileage: 63806 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0402364
Coding: 0000100
VCID: 334BC1E4522E49B
2 Faults Found:
02617 - Satellite Antenna (R170)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 173
Mileage: 63699 km
Time Indication: 0
Date: 2000.00.00
Time: 14:27:02
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 173
Mileage: 63699 km
Time Indication: 0
Date: 2000.00.00
Time: 14:27:02
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06N5C2
Coding: 0013889
VCID: 6CF91A984F90D63
Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 832BD124C20EB9B
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 954 R HW: 1K0 920 954 R
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H724V0R8
Coding: 0023203
Shop #: WSC 05074 444 53492
VCID: 3B5BE9C47A7E81B
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 140708F2001693
Coding: ED807F070003021002
VCID: 354FFFFC5C5A57B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1222
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000602388814
Coding: 0001205
VCID: 6FC30D947E862DB
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A75DC8085E4083
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 1B900F880186483F2D04058FB0880F0488DCA0
VCID: 8429D238C700BE3
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000328988819
Coding: 0001204
VCID: 70C10EE863B8323
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 38
Reset counter: 57
Mileage: 63869 km
Time Indication: 0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K3059173
Coding: 0500040004
VCID: 61E77BAC78528BB
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003422769
Coding: 0001168
VCID: 76CD38F001DC1C3
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003406760
Coding: 0001168
VCID: 77D335F406D665B
End ---------------------------------------------------------------------
#4
Posting an Auto-scan is part of the VAG-COM Diagnostic Forum rules, thank you.not sure how a scan will help when i took a screen shot of what i would like to change? anyway here one is
1204 = Old Coding
1172 = New Coding - [Do it!]
Subtracted [32] from 1204 as per the information within the 'pop up as a balloon'.
See this link for more information.
http://www.ross-tech.com/vag-com/tou...de_screen.html
