Results 1 to 7 of 7
Thread: 1990 AC compressor tensioner bolt missing! need replacement
  1. Junior Member wrathofpaul's Avatar
    Apr 4th, 2012
    1990 VW Cabriolet, 2011 Chevy Camaro SS
    08-07-2012 03:49 PM #1
    my belts are squeaking and loose, so I went to adjust the AC compressor belt and I noticed that little adjuster bolt is missing (must have somehow gotten loose and fell off) now I need a new one. does anyone know where I can get one? Thanks!
    Nov 13th, 2010
    Tacoma
    1987 Cabriolet
    08-07-2012 03:54 PM #2
    Quote Originally Posted by wrathofpaul View Post
    junkyard, there shouldn't be any shortage of cabbys there.
  3. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    08-07-2012 04:52 PM #3
    If its the bolt that has the star wheel attached, germanautoparts.com has them for sale new.
  4. Junior Member wrathofpaul's Avatar
    Apr 4th, 2012
    08-07-2012 05:01 PM #4
    i adjusted the alternator bolt (the star shaped one) just for kicks, and it seems to have worked. I still have a missing bolt connecting the AC compressor to the car, so i think I still need to get a new one. also the power steering seems to squeal when i turn the wheel to max, the belt is tight though. fluid is fine. is that normal or is the PS pump dying?
  5. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    08-07-2012 08:29 PM #5
    Go to a wrecking yard, and find a older rabbit/Cabriolet and take the old style tensioner bracket off, and get the adjuster bolt set up instead of the star. It is easier to adjust and keep squealess.
    Where are my grounds ?
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    09-18-2012 11:23 PM #6
    starting my own thread..
    Mar 17th, 2012
    Rochester, NH
    1989 Cabriolet
    09-18-2012 11:27 PM #7
    if i remember right i have belts running like the red confuguration and then the alternator going to the middle pulley (water pump?)
