Results 1 to 24 of 24
Thread: Who can identify this?!
  1. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-07-2012 04:17 PM #1
    I just picked up this 2007 gti and I was changing the oil the other day. I noticed this part (pic above). I thought the car was completely stock but the previous owner installed this. I'm not sure if it's the Forge DV or the atmospheric spacer (link below).
    http://www.ecstuning.com/News/Forge_...ves/ES1832412/
    Anyone know? Thanks in advance.
  2. Member Jay-Bee's Avatar
    Sep 22nd, 2007
    North Alberta
    B7 A4 Avant 2.0T
    08-07-2012 04:33 PM #2
    Looks like the DV spacer to me.
    It's only 3 bolts to pull it off.
    I may be wrong but I thought these only fit on the commonly failing older diaphragm DV?
    I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
    2007 A4 Avant 2.0T Q/MT
    2000 VW Golf 2.0 [Sold]
    Feb 25th, 2012
    Miami, FL
    BPY VW GTI
    08-07-2012 04:58 PM #3
    Quote Originally Posted by Jay-Bee View Post
    2nd.
  4. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-07-2012 05:00 PM #4
    Thanks! To be honest I have no idea on the older diaphragm
  5. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-07-2012 05:01 PM #5
    I'm wondering if i should pull it off and just replace it with the Rev DV
  6. Member Jay-Bee's Avatar
    Sep 22nd, 2007
    North Alberta
    B7 A4 Avant 2.0T
    08-07-2012 05:29 PM #6
    Quote Originally Posted by chadk View Post
    IMHO, yes, yes you should.
    Feb 25th, 2012
    Miami, FL
    BPY VW GTI
    08-07-2012 06:32 PM #7
    There's replacing broken parts, and there's preventative maintenance; this is neither. If it ain't broke don't fix it.
  8. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-07-2012 07:17 PM #8
    Quote Originally Posted by albinorineo View Post
    True, true..
    Thanks for the help guys 👍
  9. Senior Member MFZERO's Avatar
    Mar 13th, 2002
    Haverhill, Ma.
    2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
    08-08-2012 08:23 AM #9
    If he pulls the spacer out, he'll stop that oil leak that it is causing.
  10. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 08:54 AM #10
    Yeah I was also concerned about the oil that is on the spacer..
  11. 08-08-2012 09:15 AM #11
    Looks like a lot of blow-by. I bet when you take off the DV it will pour out a bit.
    Some people say that it's normal. I can tell you my GTI gets its fair share of being hammered on and was clean as can be at the DV when I replaced it recently.
  12. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 09:30 AM #12
    Quote Originally Posted by xtravbx View Post
    Hmm.. I should have pulled it off
    When I changed the oil over the weekend, maybe this weekend I'll take a better look at it. The gti goes into the shop tomorrow to get an outer cv boot replaced so I might have it checked while it's on the lift
  13. 08-08-2012 11:29 AM #13
    Remove the spacer, and check the diaphragm. It's easy to see when the diaphragm is failing. It'll have cracks that show up when you gently push on or twist the rubber material.
    If it's failed, re install it and order the new RevD version. no sweat. Car should run ok on the failing diverter.
    06' MKV GTI 6MT - APR Stage 1 - Upgraded OEM DV
    Dub on......
  14. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 01:49 PM #14
    Reinstall with the revD and the spacer or no spacer?
  15. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 02:25 PM #15
    The car makes a hissing sound, coming from the DV i would suppose, when i give it gas. When the turbo spools and im in boost.. no more hissing sound.
  16. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-08-2012 04:25 PM #16
    Time to upgrade to a new D DV or a Forge unit -
    Click - Here
  17. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 04:28 PM #17
    Will be ordering the D DV in the next day or so thanks
  18. 08-08-2012 04:37 PM #18
    Oh and yes - don't use the spacer. It's just a toy.
  19. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-08-2012 04:52 PM #19
    thanks for the help! appreciate it
  20. Member SCIROCCO SPEED's Avatar
    Dec 6th, 2002
    Colorado
    86 Golf (RIP), 88 16v Scirocco, 07 Gti, 73 SuperBeetle, and no TCL darlings.
    08-09-2012 12:07 AM #20
    The spacer works with the Rev D as well.
    Engineers do it better.
  21. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    08-09-2012 09:36 AM #21
    No problem, PM me if you need anything else!
    Andy
  22. Member
    Aug 10th, 2001
    Long Beach, CA
    07 CW GTI
    08-09-2012 10:04 AM #22
    BTW, I have a Rev D and oil all over as well. It doesn't really drip, but its there. I replaced the valve and its still there. I think its blowing past the o-ring. The car runs fine.
    John
    I'd stop drinking beer, but I'm no quitter.
  23. Member chadk's Avatar
    Nov 10th, 2011
    Western MD
    Candy White GTI
    08-09-2012 11:39 AM #23
    Quote Originally Posted by Elwood View Post
    yeah im kind of puzzled on the oil that is on the spacer/DV.. just coated on it..
    EDIT: make sure the old o-ring from the original DV didnt stick and stay there causing you to have 2 o-rings, I read on the mkvgolf forum of someone doing that
  24. Member
    Aug 10th, 2001
    Long Beach, CA
    07 CW GTI
    08-09-2012 12:07 PM #24
    Good call. I'll check next time I have the skid plate off.
    John
