Results 1 to 12 of 12
Thread: Best Power Window Regulators
    Oct 10th, 2008
    Hershey, PA
    Jetta's 97GLS & 98 GLX & 99 Passat 1.8T
    08-07-2012 06:48 PM #1
    OK, I've replaced several window regulators over the last few years and I only get about 6 months out of them. Been buying the cheap ones from Rock auto. Can anybody recommend a reliable brand for my mk3 Jetta's?
  2. 08-07-2012 09:48 PM #2
    yup oem crank manual windows lmao
    Jun 14th, 2007
    E36, R32
    08-07-2012 09:55 PM #3
    if you want to retain power windows, the ONLY ones to purchase are OEM from the dealer.
    the price sucks, but from my experience, they last years compared to a couple months for the cheap ones.
    welcome to the layer cake
  4. Member sic_null's Avatar
    Jun 21st, 2012
    A-K-Rowdy
    98 GLX VR6, 86 Mercedes 300D, 01 Jetta Wolfsburg
    08-07-2012 11:15 PM #4
    Fact of the matter is. These regulators are a terrible design. Its not "if" they fail, its "when"
    OEM regulators seem to be able to get the longest run time. If you have the cash.
    Or. Keep buying the aftermarket ones.
    My old ABA went through 3 drivers. 2 passengers and 2 rears in a 2 year period....Ice on the windows in the winter is what kills them.
  5. 08-07-2012 11:45 PM #5
    I have broke one in 250,000miles. They have never been an issue for me like everyone else seems to have. Keep them clean and lubed, and use OEM regulators, and they last 100k miles easy.
    Someone needs to make Bronze clips to replace the OEM piece, so that they are never a worry again for the guys that seem to break them.
    Paging 42DD.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  6. Member Sky-Fi's Avatar
    Jan 19th, 2008
    Charleston, SC
    97 LG5R Jetta GLS
    08-08-2012 12:56 AM #6
    Yeah, OEM all the way for them. From the three failures I've seen so far, flimsy plastic guides/clips are to blame. If they were made of metal, they would be indestructible, or damn close to it.
    First one (LR) broke at 95k on the car. Was factory and lasted 14 years. Got a new OEM one and after about two years, it acted up again. Different flimsy plastic piece broke, but it was able to be fixed with an 8-penny finishing nail and a zip-tie. Still working great.
    Second one broke (LF) over this past winter (no frost/ice on the window when I used it). It had been making some quiet/muffled noises for a few months beforehand, and the clunk at the top when it closed got louder and louder, until one day, there was a clunk, bang, and then the all-too-familiar sound of bits and pieces of shattered plastic raining down inside the door. I took the door apart to see if it would be another zip-tie fix, and it is most definitely not.
    The cable had jumped off one of the pulleys, so I put it all back together and tested it outside of the door with three full cycles and it seemed fine. Put it back in the door and hooked the glass up, when two cycles and it was fine. Third time down, there was a bang. Cable jumped again. I got it back together without removing it from the door, went all the way back up with it, another bang, more plastic rained down, I unplugged the motor and put the door card back on. It is holding itself up and doesn't leak. Front regulators are more pricey than rears.
    I really don't know why so many people on the 'tex are so anti-power windows. Unless you just abuse the hell out of it, or get cheap parts, two separate failures within three years on something that is now 16 years old is pretty damn good by just about any standards. In industrial terms, that's a MTBF of over 125,000 hours, and you have to consider that even in 16 years, there is probably only less than 10 hours of actual mechanical use.
    We need a series like this state-side. I'm in if there is one, or will be one. VW Cup 2013, anyone?
    Oct 10th, 2008
    Hershey, PA
    08-09-2012 06:35 AM #7
    With mine it's usually the cables binding up.
    Oct 10th, 2008
    Hershey, PA
    08-09-2012 12:22 PM #8
    Where can I get VW OEM window regulators for the best price?
  9. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    NJ - AKA - Earth's armpit.
    Too many
    08-09-2012 12:35 PM #9
    OEM all the way for ignition switches, coils, and power window motors.
  10. Member Sallad's Avatar
    Aug 29th, 2004
    Kelowna, BC
    '94 Jetta 2.0 16v
    08-09-2012 11:52 PM #10
    Quote Originally Posted by sic_null View Post
    No, the fact you are trying to operate a frozen window is what kills them.
    I blame operator error for most failures. I'm betting most people never clean or maintain the system. Over time they get dirty and cause more drag.
    To answer the OP:
    ...your arm.
    Pro Patria
    Making power, 4 valves at a time.
    MkIII 16v Club.
  11. Member The Big V's Avatar
    Jul 11th, 1999
    NYC
    '99 mk3 Golf Wolfsburg (Black, 5spd, 200k mi +)
    08-10-2012 02:53 AM #11
    if the cables keep binding up then def get all used OEM ones...the motors are better in the oem ones too..........test them...clean them and then lube them all up nicely...i use a similar method to the DIY fix for the plastic window clips breaking--a small hex bolt with nuts locked on the other end and 2 zip ties on the backside of the clip (inbetween the ends of the bolt to secure it in place) will hold the cable line tight and prevent any further breaking. havent had a problem with windows since! i cleaned the crap outta the window edges (door edges) and cleaned the glass with a blade. i now run window tint and keep everything clean with no worries. i also made a couple extra window clip fix kits and put them in my trunk with all my other spares (extra used oem ignition coil, check!), and tools etc. good luck..heres the orig diy link (there was one from ohiovw.com too but that seems to be gone now..)
    http://forums.vwvortex.com/showthrea.....lots-of-pics
    take the road less travelled...
    __________________________
    GermanAutoParts.com | TyrolSport.com
    BrokeVW.com | Dan Reed's DIY VW site
    Oct 10th, 2008
    Hershey, PA
    08-13-2012 12:22 PM #12
    Well I ordered the VW regulators from 1stvwparts. Hopefully they will last more than a year. Should be here on friday.
