Results 1 to 17 of 17
Thread: Interior LED Panel Lighting and License Plate
  1. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    2012 Volkswagen Passat 2.5 SE
    08-07-2012 07:21 PM #1
    I was looking to do an interior LED swap and came across these..
    http://store.ijdmtoy.com/Volkswagen-...-p/vw-df10.htm - For front and rear dome lights, when you hit checkout they also offer vanity lights..
    and
    http://store.ijdmtoy.com/Audi-TT-Q5-...e-led-c-s5.htm - License Plate LED
    Claims to be Error/Code Free and seems to have more LED (brighter lights). Price is reasonable as well, what do you guys think?
    Jun 2nd, 2012
    Hawaii
    2012 Passat TDI SEL
    08-09-2012 11:52 AM #2
    I already got these license LED's and they do not work well for the B7. The electrical connector will not mate with the car's electrical connector (totally different) plus you got to figure out a place to stick the resistors that they do not show in the picture, which make them error free. They fit in the hole perfectly, but that's where the perfection ends. You can always chose to use scotchlocks and splice them in, but I chose not to do that. they are nice and bright as well. Just not P-n-P. I sent them back and got a refund. Note that the description states for 08-10 Passat. I'm still looking for the perfect plug and play LED lamps. For the interior lamps, You can use any LED lamp, as the interior bulb circuits are not monitored for current draw. I put some cheapo red LED's from Ebay in my footwell lamps - red is good for not ruining your nightvision - and no error codes!
    2012 SEL TDI DSG - Platinum Gray with Moonrock
  3. Member capclassicv2's Avatar
    Mar 2nd, 2007
    Maryland
    2012 VW Passat
    08-09-2012 12:29 PM #3
    I haven't touched my license plates.
    But I have switched out every interior bulb with an LED bulb. I did map/dome lights, glove box, footwell and trunk.
    At the moment these are the only pictures i have.
    CURRENT: 2012 VW Passat 2.5 SEL Premium
    PREVIOUS: 2009 VW Tiguan SE
    PREVIOUS: 2006 VW Passat 2.0T
    PREVIOUS: 1997 Oldsmobile Achieva
  4. Junior Member
    Apr 17th, 2009
    melbourne fl
    2012 passat tdi sel
    08-09-2012 09:27 PM #4
    Go to ecstuning and get the ones for the 2011 audi a 4 s line they work I have them in my car
  5. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    08-11-2012 04:12 PM #5
    Quote Originally Posted by jimmygez View Post
    What is the ES# for the part you ordered? Want to make sure I order the correct ones.
    And thank you guys for your responses, very helpful!
  6. Junior Member Griff_333's Avatar
    Apr 10th, 2011
    NOVA
    '13 B7 TDI SE M
    08-14-2012 11:21 AM #6
    What you up to in that back seat with all that REDNESS going on???
    '13 Passat TDi SE M, Eagle GT wrapped SAGITTA 19s
    '03 Ford SD 250, 7.3L PowerStroke
    '73 Bronco Ranger, Rollerized 5.0
    Humility Before Honor
  7. Member capclassicv2's Avatar
    Mar 2nd, 2007
    Maryland
    2012 VW Passat
    08-14-2012 11:46 AM #7
    Quote Originally Posted by Griff_333 View Post
    I went with a theme. Since most of the instrument panel is white accented by red, all the interior LEDs are read except the front map lights (so I can actually read stuff). It's actually a pretty good brightness in person, the picture just makes it look extra red. I'll try to take some better pictures one of these days if I can.
  8. 08-16-2012 08:37 AM #8
    Tried the ones from ECS Tuning and I ran into the same issue as Norm. The connectors are NOT the same and they also come with a metal canbus box that has to be mounted somewhere or it would rattle around inside if not. The only other option I haven't tried are some of the error free LED bulbs that have the built in resistor on the actual bulb. anyone try these yet??
  9. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    08-16-2012 10:03 PM #9
    Right now I am using these. They light up great but give me a biulb out error.
    http://www.ebay.com/itm/270940860629...84.m1497.l2649
  10. Banned
    Aug 16th, 2012
    Guangzhou, China
    08-17-2012 12:05 AM #10
    very nice, why not garling your out side car? such as headlight
  11. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    08-18-2012 10:30 AM #11
    Anyone know if these will fit and if the plugs match for the License Plate?
    http://www.amazon.com/Direct-Visibil...+License+Plate
    Jun 2nd, 2012
    Hawaii
    2012 Passat TDI SEL
    08-20-2012 03:08 AM #12
    Hard to say without a good picture of what's inside the adapter socket. Here's a pic of the license lamp fixture with the plug removed. It looks like it may, but caveat emptor!
  13. Member JJS119's Avatar
    Aug 25th, 2008
    NYC
    2013 Passat SE 2.5 Sunroof & Navigation
    08-20-2012 08:10 PM #13
    Cant we get the OEM MK6 license plate light or do those throw codes? I just need HID's and LED license plate lamps that wont throw a code!
    2013 Passat SE 2.5 with Navigation and Sunroof Navy Blue Metallic
  14. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    08-20-2012 08:16 PM #14
    A lot of places offer LED Lamps for the MK6, I'm just not sure if they have the same connectors. If anyone can verify its the same and they are compatible, I'll order a set and post the results.
  15. Junior Member Zarar's Avatar
    Jul 29th, 2012
    Long Island, NY
    08-20-2012 08:30 PM #15
    Quote Originally Posted by JJS119 View Post
    As for the HIDs, seems like there are members here who've had success with HID Kits from USP Motor Sports. Canbus HID kit with the MK6 Bulb adapters. Plan to order myself a set later this week as well.
    http://uspmotorsports.com/product_in...roducts_id=632
  16. Member JJS119's Avatar
    Aug 25th, 2008
    NYC
    08-20-2012 08:45 PM #16
    Thank you for that link, I will be purchasing that in 4300k right now.
  17. Member JJS119's Avatar
    Aug 25th, 2008
    NYC
    08-21-2012 07:57 PM #17
    Zarar, I purchased the kit. Thanks a lot for the link. It comes with everything you need for the install, including the MK6 bulb adaptors so you don't have to butcher your factory ones.
    I purchased the MK6 adaptors off eBay before I even had a kit picked out a few days ago for $3.00 with free shipping, I look at my statement today and see he added an extra $20. I am going to dispute the **** out of that, but that is a different story
    I shipped the kit via UPS Ground so it should be here by Thursday the latest. I will let you know how the install goes. I expect to be extremely easy, since my right side low beam went out the other day, is very easy to get to access, the other side seems easy to access, and I put 4,300 HID's in every car I owned unless they came from the factory with them.
