VWVortex.com - TDI DSG slight shift flare's
    Results 1 to 7 of 7
    Thread: TDI DSG slight shift flare's
      Aug 26th, 2006
      2013 Passat TDI SEL Premium
      08-07-2012 10:56 PM #1
      This may be normal. It is our first DSG transmission. When accelerating at a normal rate with other traffic the DSG has a slight shift flare between all gears like there is a slight lag between the clutch swap. I thought it was supposed to be instantaneous. Is this correct? I'm thinking maybe it's still going through the adaptive learning thing before it tighten's things up but just want to see how they're supposed to drive. For all I know it's normal.
      Sep 23rd, 2002
      2012 Passat V6 SE (Night Blue ext / Black int)
      08-08-2012 09:37 AM #2
      Not sure what you are experiencing but there is no adaptive learning with the DSG.
    3. Member compu_85's Avatar
      Aug 17th, 2004
      Springfield, VA
      08-08-2012 10:50 AM #3
      I think I may have noticed this too... a super quick blip in the RPMs as the shift happens. I wouldn't worry.
      -J
      2012 Passat TDI SE DSG. 99,000 miles. LED tails, VCDS tweaks (wipers, alarm, cluster)
      2004 Touareg V10 TDI. 150,000 miles.
      1999 Jetta "GLX" TDI. 309,000 miles. RCIII, BV49, S520, Knois.
      1991 Mercedes 350SDL. 230,000 miles, 60k on the replacement motor
      Past: 91 Jetta ECOdiesel. Totaled. 92 Jetta ECOdiesel. 87 Audi 5000S Q. 85 Jetta 1.8.
    4. Member turboDSG's Avatar
      Feb 1st, 2009
      Carlsbad, CA
      GLI Gen 3
      08-08-2012 11:17 AM #4
      Quote Originally Posted by Banshee365 View Post
      Nothing in life is instant, not even instant coffee
      DSG is crazy fast compared to other forms of shifting but it still has its occasional quirks and hiccups too. Someone above said it is not adaptive.. well the DSG may not but the cars definitely respond to different styles. Many times after really romping my GLI, I'd go back to regular driving around a corner or something and it would stumble around a few shifts until things were more constant again.
      The biggest factor I've found in what you are describing though is shift points and how the turbo is boosting. If you are driving slow but it's spooling up or hitting peak boost it makes the shifts flare a bit. In the same situation I'd put it in tiptronic and shift either below any boost or higher into it and it would be smooth. This is mainly in stop and go erratic city driving only.
      2014 GLI Autobahn DSG | Unitronic Stage 1 | Neuspeed P-flo Intake | Maniacs Paddle Shifter Extensions | Carbon Fiber Wrap Interior Trim | deAutoKey HIDs & LEDs | Yellow Laminex Fogs | 35% Tint | 3M Gloss Black Roof | VCDS in North San Diego County Coast |
    5. Junior Member
      Jul 10th, 2012
      2017 GTI Mk VII DSG Autobahn. 2016 RAM 2500 Power Wagon
      08-08-2012 04:00 PM #5
      Hm... I've never experienced this...... Or... At least never noticed it :-)
      I love how quick the shifts are with the DSG compared to a traditional automatic
    6. Member
      Aug 26th, 2006
      08-08-2012 11:21 PM #6
      I'm not super-worried, I pick up on really little things like this. Maybe I'll just take a quick video soon and post it up. If pictures are worth a thousand words, videos have got to be worth more!
    7. 08-09-2012 07:47 PM #7
      DSG shifts are very quick and crisp.....what you are feeling is sloppy rear mount. I installed the HPA TDI mount and it is awesome, except for the added cabin noise.
      I love the DSG, just wish the HPA mount didn't add cabin noise.
      Current: 2012 VW Passat TDI SEL Premium is used for Off-Road Use Only
      Previous: '07 VW GTI 2.0T, '07 BMW K1200LT, '00 VW Golf 1.8T (4DRGTI), '92 GTI 2.0 16V, '04(2) Nissan Altima, '83 Rabbit GTI, '85 Golf GTI, '86 cabrio, '91 GTI 2.0 16V, '93 Passat VR6 and a couple others that I won't mention.
      My 2012 Passat TDI SEL Premium Fuelly Record
