Results 1 to 7 of 7
Thread: Sticky gears?
  1. Member ParkeR32's Avatar
    Mar 22nd, 2012
    Jackson, NJ
    MkIV .:R32
    08-08-2012 10:02 AM #1
    So i was driving home from work yesterday and out of no where i couldnt get the shifter to get over to 1st or 2nd gear. i had to wiggle it around and push down on the shift knob and it eventually went over. Happened a few more times yesterday and like twice on my way to work today. It feels kind of sticky or something, not really moving as freely as it used to. What could be causing this? thanks
  2. 08-08-2012 10:04 AM #2
    Quote Originally Posted by ParkeR32 View Post
    Oh dear sounds like the selector fork issue!....check the cables and selector on top of the gearbox before you panic.
    MK4 R36 x Precision 6776 Turbo = Large Grin
  3. Member ParkeR32's Avatar
    Mar 22nd, 2012
    Jackson, NJ
    MkIV .:R32
    08-08-2012 10:08 AM #3
    Quote Originally Posted by Slapbladder View Post
    Ive had it happen much worse before where no matter what i did i couldnt get it in 1st or 2nd. I had to start in 3rd gear but it eventually went back to normal and was fine till yesterday. Is the selector fork issue an easy fix?
  4. 08-08-2012 10:13 AM #4
    Selector fork/forks is gearbox out.
  5. Member gnatman's Avatar
    Jun 2nd, 2007
    BMP MKIV .:R32T, B8A4, 86Z28(trkhor)
    08-08-2012 06:17 PM #5
    do you have an aftermarket clutch or stock clutch?
    Click me for apparel
    HAVE YOU SEEN THE VIDEO?
    I print apparel for a hobby. PM ME FOR DETAILS
    .:::Exklusiv:::.
  6. Member ParkeR32's Avatar
    Mar 22nd, 2012
    Jackson, NJ
    MkIV .:R32
    08-08-2012 11:47 PM #6
    Quote Originally Posted by gnatman View Post
    stock clutch
  7. 08-09-2012 03:06 AM #7
    forgot to mention it could also be the slave cylinder for the clutch.....it might need the fluid changing or the slave cylinder is buggered. If you look under the car on the botton of the gearbox case is there any oil?
