Results 1 to 24 of 24
Thread: APR Presents: VWR 6-Piston, 352mm x 32mm 2-Piece Performance Brake System!
  1. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    08-08-2012 11:57 AM #1
    Product Page:
    http://www.goapr.com/products/brakes_vwr_vag_a5.html
    APR is pleased to present the Racingline range of parts developed by Volkswagen Racing UK and distributed exclusively through APR's global dealer network. To learn more about VWR, please visit Volkswagen Racing UK's website.
    The VWR Performance Brake System is a highly recommended upgrade for any stock or modified vehicle and perfectly complements APR's and VWR's power and handling modifications. The VWR Performance Brake System is track proven through the Volkswagen Racing Cup in the UK, quality stress tested to strict OEM standards beyond that of TÜV and DOT and is fully manufactured in the UK.
    Quick Facts
    • 6-Piston, Light Weight, Low Profile, Red/Black/Blue Forged Calipers
    • 352mm x 32mm 2-piece, Vented and Grooved Discs
    • Aluminum Bells Compatible with VWR Interlocking Hub Spacers
    • Aluminum Mounting Brackets with Racingline script
    • Braided Stainless Flexible Brake Lines
    • Performance Street Pads in a Non-Proprietary Standard Size
    • All Mounting Hardware Included
    • Optional VWR Interlocking 5mm, 7mm and 10mm Hub Spacers
    • Fits 18 Inch Wheels and Larger
    • Caliper Design Specific for VAG Master Cylinders
    • Reduced Unsprung Mass with a Total Weight of 29 LBS Per Side
    • Manufactured in the UK
    • Replaceable Discs and Pads Available
    Brake Calipers
    The 6-piston front calipers feature a piston array of varying diameters to ensure even pressure distribution across the entire pad surface. Unlike many generic braking systems on the market today, light braking under daily driving will not result in a 'grabby' or harsh, on/off braking feeling. This is because the VWR braking system is specific to each vehicle and was expertly matched to the OEM master cylinder and brake servo assistance. This ensures pedal feel is nearly identical to stock in normal driving conditions, yet capable of providing tremendous stopping power in high demand situations.
    The calipers are forged from lightweight aluminum and designed to house large brake pads. The forged design provides intrinsic compressive stresses to help combat the negative effects of caliper flex, allowing improved force distribution and reduced vibration. Each unit features a thin caliper profile to aid in clearances and weight savings while not sacrificing structural integrity, even in the most demanding environments.
    Calipers are available in red, black or blue with Volkswagen Racing script.
    Brake Pads
    VWR provides performance street brake pads with each system. However, a standard pad size was chosen to afford customers the ability to run their favorite brands and compounds without proprietary restrictions.
    Caliper Carriers
    VWR provides strong and lightweight aluminum caliper carriers, with Racingline script, to properly mount the brake calipers. Standard mounting hardware is included and longer hardware is available for those with uprated factory aluminum uprights.
    Brake Rotors
    Massive 352mm x 32mm ventilated and grooved 2-piece disc surfaces provide dramatically better braking, both in terms of pedal response and resistance to fade, under hard use. To reduce brake fade, the ventilated design dissipates heat while the grooved surfaces evacuate gases released from the pads. The 2-piece design further aids in heat dissipation while reducing unsprung mass through the use of a lightweight aluminum bell. Because the bell housing is separate from the disc and reusable, replacement discs are less expensive.
    A key feature of the VWR Braking System is the use of Interlocking Hub Spacers which offer several benefits in one convenient package. The VWR Interlocking Hub Spacers allow for proper caliper clearance and/or extra wheel spacing for looks and handling without increasing vibration, or negatively impacting drivability.
    A common problem with larger than stock brake systems is an inability to use OEM and some aftermarket wheels due to the larger caliper width contacting the wheel's spokes. The available VWR Interlocking Hub Spacers allow for an additional spacing of 5mm, 7mm or 10mm depending on application needs. Each spacer locks into the rotor's bell housing to ensure no unnecessary movement or vibration is created under acceleration and braking.
    This is a key benefit for customers swapping wheels during harsh winters, daily driving or track use. Within reason, no matter the offset, the VWR Interlocking Hub Spacers allow for issue free fitment of different offset wheels without swapping bell housings, or worse, removal of the entire braking system.
    VWR Brakes are designed for 18" and larger diameter wheels. Each Interlocking Hub Adapter is sold separately.
    Brake Lines
    The VWR Performance Brake System includes braided stainless steel brake lines to improve the braking system's effectiveness and longevity over conventional OEM rubber lines. Rubber lines have a tendency to swell or expand under heavy braking creating a soft or spongy pedal. However, stainless steel lines remain true to their form providing a more responsive and firm brake pedal. Abrasion and corrosion resistant, these lines will stay functional and looking good for years to come.
    Bleeding the braking system is a required step in any brake caliper or brake line install and marks a perfect opportunity for upgrading to Motul’s premium street or track brake fluids. APR recommends Motul DOT 5.1 for street and light track use and Motul RBF 600 or 660 for track use only. See the Motul section listed below for more details on each fluid.
    Lightweight, Strong and Proven
    An obvious feature of the VWR Performance Brake System is an increase in stopping power, but an often-overlooked benefit is an increase in acceleration, ride comfort and handling through a reduction in unsprung mass. Typical OEM brake systems on VAG A5 platform vehicles (Golf, Jetta, A3, etc) weigh 33 lbs per side (Even more for Golf R, S3 and larger systems) while the entire VWR system weighs in at 29 LBS with pads!
    Manufacturing and Quality Control
    Through years of brutal testing in the Volkswagen Racing Cup, the VWR Braking System has proven to be a strong and reliable system for both street and track applications. Each system is manufactured in the UK and sample units are run through a battery of tests as seen below.
    VWR Brake Kits
    VWRPB001 - $2,799.00 - VWR Performance Brake System - Red
    VWRPB002 - $2,799.00 - VWR Performance Brake System - Black
    VWRPB003 - $2,799.00 - VWR Performance Brake System - Blue
    The VWR Performance Brake System includes caliper carrier bolts for the standard OEM spindles / uprights. For use with uprated OEM Aluminum Spindles / Uprights, please purchase the larger Caliper Carrier Bolts listed below.
    VWRPB016 - $124.00 - 2 VWR Interlocking Hub Spacers - 5mm
    VWRPB017 - $124.00 - 2 VWR Interlocking Hub Spacers - 7mm
    VWRPB018 - $124.00 - 2 VWR Interlocking Hub Spacers - 10mm
    The VWR Interlocking Hub Spacers designed for the VWR Performance Braking System and are not designed as a standalone product.
    Replacement Parts
    VWRPB009 - $924.00 - 2 VWR Replacment Rotors
    VWRPB007 - $192.00 - 4 VWR Replacement Brake Pads
    The VWR Replacement Brake Pads are designed for the VWR Performance Braking System and are not replacements for your OEM brake pads.
    The VWR Replacement Rotors are designed for use with the VWR Performance Braking System and are not replacements for your OEM brake rotors.
    Other Parts
    Coming Soon! - 2 sets of VWR Caliper Carrier Bolts for Vechicles with Uprated OEM Aluminum Uprights (TT/S3/Passat/CC/Cupra, Please Check!)
    Motul Brake Fluid
    Motul's premium line of brake fluids are specifically designed for use in both street and racing applications. There is no one fluid designed for use as the "best" formula in every situation, therefore Motul offers fluid for street use as well as track only use to ensure the maximum stopping power and fluid life in each respective application. By offering superior boiling points, pedal stiffness will remain lap after lap giving you a competitive edge in demanding environments.
    Street - DOT 5.1
    Street - DOT 5.1 - 100% synthetic brake fluid on polyglycol basis for all types of hydraulic actuated brake and clutch systems in accordance with DOT 5.1, DOT 4 and DOT 3 manufacturers' recommendations. Specially designed for anti-locking brake system (ABS). Dry boiling point of 522°F (272°C).
    Recommendations: Recommended as an OE brake fluid upgrade for street and light track use. Follow standard factory drain intervals.
    100951 - $7.96 - 500 ml Bottle
    Racing - RBF 600 - Racing DOT 4
    Racing - RBF 600 - Racing DOT 4 - Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. The package is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point helps prevent vapor lock and brake fade during hard use, with excellent recovery time. 313°C dry - 216°C wet.
    Recommendations: This is a racing brake fluid designed for track use only and should not be used on street vehicles. Fluid should be bled and replaced before and after track events.
    100949 - $14.77 - 500 ml Bottle
    Racing - RBF 660 - Racing DOT 4
    Racing - RBF 660 - Racing DOT 4 - Very high dry boiling point of 325°C and a wet boiling point of 204°C. For all types of hydraulic brake and clutch actuators requiring non-silicone synthetic fluid. Specially designed to resist extreme temperature generated by racing carbon and ceramic brakes allowing a minimal air entrance for brake cooling.
    101667 - $22.04 - 500 ml Bottle
    All of these items are available on www.goapr.com or through an APR dealer near you.
    Follow us on facebook for more updates! http://www.facebook.com/APRMotorsport
    Thank you and Go APR!
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality remains long after the sweetness of low price is forgotten.
  2. Member rlfletch's Avatar
    Jun 11th, 2000
    MkV R32, Focus Electric
    08-08-2012 12:34 PM #2
    Damn. Finally a kit I would put on my car. Too bad I am short the $2800 right now. Saving my pennies.
    Mercedes typically makes awful manual transmissions and fantastic auto transmissions. Choosing the stick would be like saying, "Y'know, that Natalie Portman is pretty hot, but if she grew some hair on her legs and had a dong, she'd be just right."
    You Saab guys are worse than the VW fans. All 3 of you.
  3. Member mfbmike's Avatar
    Feb 5th, 2011
    305 Miami, FL
    2008 CW R32, 1983 CW Rabbit LS
    08-08-2012 01:14 PM #3
    Quote Originally Posted by rlfletch View Post
    What's wrong with the other kits?
    Holy Milltek.
    Tarmacs cut it close.
    Miami Vase
    Cams A Make Her Dance
  4. Member Slave IV's Avatar
    Nov 15th, 2010
    B5 S4, MkV R32, W203 C240, W123 300D Turbo, W210 E320 4Matic
    08-08-2012 03:38 PM #4
    Nice! This is most likely the only bbk I would get for my car besides brembos. I like that these are a bit more oem+ but too bad they are not monoblock calipers.
    I don't know enough about the other options (which is another reson id skip) to comment much about them but I'd rather go with a trusted, tried and true company that specializes in brakes than someone who just makes brakes along with a bunch of other parts they think they can sell. There are only a few really great brake companies in the world and AP (who makes the vwr brakes) is one of them. Brembo would be the best, followed by Alcon and I probably wouldn't use anything besides those if I was paying for a bbk.
    If your gas cap light comes on even if you think you tightened the cap, try pulling on the cap as you tighten it. Worked for me.
    Help us with suspension specs!
    Vag Evolution: MkI Rabbit -> MkII 16v GTI -> B5 S4/MkV .:R32
  5. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-08-2012 04:13 PM #5
    I have a set on my personal car and they, along with the suspension, made me fall back in love with it again.
  6. Member
    Mar 30th, 2009
    Ft Lauderdale
    2008 VW R32
    08-10-2012 03:49 AM #6
    Quote Originally Posted by Slave IV View Post
    MOV'IT is probably the best but are not affordable (if you can afford it by them). Brembo is the most popular but rumor had it some kits were coming out of China. Nothing against China just not sure about quality control. I personally would take Alcon over Brembo for track days. Baer is the manufacture for HPA's kit. I believe they have been in the game for a while but mainly do American cars. Willwood is reputable as well and I have 6 piston front four piston rear kit for my E46 330i ZHP. StopTech which is the performance end of Centric. The kit seems to be quality and has a fairly good following, but I have no experience with them directly.
    I inquired about this a while back and they people over seas seemed a bit annoyed that I asked questions about the kit. Hopefull now that APR is the vendor customer service will be better. Interested in the kit but also shoping the HPA kit as well. I do like this kit as this was my first choice.
    Guess I will have to send some questions to APR!
  7. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-10-2012 10:20 AM #7
    Quote Originally Posted by kidplatinum View Post
    Fire away!
  8. Banner Advertiser JC@DouglasVW's Avatar
    Jun 24th, 2009
    Summit, NJ
    Billet 72'd 07 GTI, Billet 6265'd 08 R32, 2010 GMC Sierra
    08-10-2012 10:29 AM #8
    I see these in my very near future.
    Douglas VW
    Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
    Innovative Motorsports + UM
  9. Member zevion's Avatar
    Oct 23rd, 2009
    Minneapolis
    2008 MkV R32T
    08-10-2012 10:55 AM #9
    I already have Brembo's, but if I didn't then I'd be all over these.
    2008 R32 | UM Software | C2/Custom Stage 5 | Jeff Atwood Approved
    Vortex Thread | GolfMk5 Thread | Old Video | Old Video Compilation | I UM | I Performance Leds
  10. Member NorEastVW's Avatar
    Oct 30th, 2011
    NH / Boston
    2008 VW R32
    08-10-2012 11:09 AM #10
    Very interested... looking forward to reading the reviews as ppl pick these up/install
  11. Member rlfletch's Avatar
    Jun 11th, 2000
    08-10-2012 12:23 PM #11
    Quote Originally Posted by mfbmike View Post
    This for starters:
    I have had nothing but bad experiences with aftermarket kits on my previous cars. These sound as close to OE as your going to get. Maybe I'm wrong but I would give these a shot over any other.
  12. Member skaven-R32's Avatar
    Jun 22nd, 2008
    Renton, WA
    MkV DBP R32 #462
    08-10-2012 12:50 PM #12
    Nice kit, and the interlocking hub spacers are a cool detail. I wonder if these will clear the OEM R32 wheels without spacers. Also do the calipers allow for "quick swapping" of brake pads? With how open the back of the calipers are, I would assume so.
    I would also like to note that the recent surge of aftermarket support in the last year for our cars is pretty sweet. So many options to choose from.
    Quote Originally Posted by dubnick32 View Post
    That guy shouldn't own an R32. I bet he goes out dancing at least twice a week.
  13. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-10-2012 12:52 PM #13
    Quote Originally Posted by skaven-R32 View Post
    They are 'quick swapable'. We did them at the track recently.
  14. Member
    Mar 30th, 2009
    Ft Lauderdale
    2008 VW R32
    08-10-2012 05:08 PM #14
    This for starters:
    That is why I like to get complete front and rear kits. I do agree with you on this kit sounding as close to OEM, manufactured to work with OEM config, more so than the others.
  15. Member Slave IV's Avatar
    Nov 15th, 2010
    08-10-2012 06:21 PM #15
    Not arguing against them as I said these are one of the top two kits I would get but just reminding everyone that VWR chimed in themselves and mentioned that the brake regulator is self adjusting so there is no need to worry about bias when putting on any BBK. If you are still concerned, the more important thing would be to calculate the total brake force/torque from OEM and compare those to whatever you end up with.
  16. Member
    Mar 30th, 2009
    Ft Lauderdale
    2008 VW R32
    08-16-2012 12:29 AM #16
    Quote Originally Posted by Arin@APR View Post
    Fire away!
    Oh no! Why did you say that? LOL!!
    What is the warranty and duration of warranty?
    If service is required, no matter if warranty or just customer desire, who handles it? Will APR service the calipers or will they have to be shipped back to manufacture overseas?
    The pad offered with this kit is what size? Does it match directly to any OEM car's brake pad currently (for example, same size as Cayman S or C6 Vette)?
    What is the hat offset versus the OEM hat offset (how far in/out the new rotor will sit)?
    Are spacers required to fit this kit under OEM conditions? Meaning that if everything is OEM, as from factory, will this kit require a spacer to work properly?
    Do you have a template of the kit to verify fitment/clearance of caliper? So I can verify if kit will fit without spacers with aftermarket wheels.
    What OEM parts will be removed and not reinstalled (like removal of dust shield)?
    Will brake sensor remain or be removed?
    Is the brake biased changed at all from OEM? By this I mean will the bias change to be more rear biased or more front biased?
    And lastly...can you get them in yellow?
    Some of these may have been answered already, and if so I apologize for asking again.
    Thanks
  17. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-16-2012 11:39 AM #17
    From VWR:
    The Company warrants that all genuine parts will be free of defects in material or workmanship for 12 months from sale by the Company. In respect of any other parts fitted or other Goods, the Company assigns to the Customer the benefits of the applicable manufacturers warranty. The Company warrants its work free of defects in workmanship for a period of 3 months or 3,000 miles, whichever occurs sooner, from the date of completion of the work.
    We will handle it for you.
    Length 152mm
    Width 54mm
    Depth 17mm
    The pads have the same dimensions as Ferodo part FRP3077H. I'm not sure if it matches any other OEM pads.
    I will ask.
    That will depend on the set of wheels you have. If you give me the wheel name, it may be possible to ask.
    Yes. I need to get that from VWR. Let me remind them.
    No oem parts are reinstalled.
    That will depend on the pads. The ones we provide don't have them.
    No
    No
    Thanks
  18. Member jmh2002's Avatar
    Jun 28th, 2007
    France
    Euro 2001 MKIV 2.8 V6 4motion (5 door) - HGP Turbo
    08-16-2012 12:04 PM #18
    ^^^ Detailed reply
    HGP-T 450PS, Unibrace, 225/40/18 AD08s, OZ Ultraleggera, Light BBK F&R, Recaro Interior, .:R extras, MFD Navi, Phatbox, JCaps, Neuspeed, PSS9s, H2Sport Stage 3, DLI-Teknik, GC links, bHPP, etc...
  19. Member
    Mar 30th, 2009
    Ft Lauderdale
    2008 VW R32
    08-16-2012 11:41 PM #19
    Hey Arin
    A few more questions to clear up some of the answers.
    When you say "We will handle it for you." in regards to the warranty...I should have been mor detailed. If the part fails I know I will contact you as I paid you directly, but who will actually service the part? Does APR have the ability to service the part or will it have to be shipped back to the UK? A followup question will come based on the response.
    I currently have Rotiorm Nue wheels, size 19X8.5 (4). I would need the template for my other set of custom ISS Forged Spia wheels, size 20X8 & 20X9.
    If I understand your reply correctly...the dust shield is being removed, correct?
    Thanks for answering the first round of questions.
  20. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-17-2012 11:11 AM #20
    Hey Arin
    If the part fails under warranty, you will ship the item here and we'll ship you a new one.
    I'm still waiting for the template and was told I would probably get it monday.
    Yes
  21. Member DarkNeo's Avatar
    Jun 18th, 2004
    SoCal
    Golf R32
    08-17-2012 04:02 PM #21
    Any chance of offering a kit for the Fastivus Raffle
    Official OG '08 .:R32 Owners Club Member
  22. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-17-2012 04:14 PM #22
    Quote Originally Posted by DarkNeo View Post
    Probably not. The system is VWR's and not ours. We're raffling off software and fuel pumps though.
  23. Member Vdub303's Avatar
    Apr 14th, 2008
    Denver
    .:R32/Miata
    08-18-2012 07:37 PM #23
    Fap fap fap
  24. Member ZPrime's Avatar
    Mar 7th, 2006
    [216 / 440] Mayfield Heights, OH
    2008 R32 #3603/5000
    08-22-2012 04:05 AM #24
    Too bad they don't sell matching rotors for the rear.
    Also too bad that the dust shield has to go, but nice that they clear stock wheels sans spacer (RB I'm scowling at you right now).
    My RB order is already placed though, VWR took way too damn long getting these over here.
    I have installed most of the popular bolt-on mods for a 2008 R32, minus suspension work. I know a lot about electronics and car audio, and have experience with VCDS ("vagcom"). I'm a radar/lidar countermeasure enthusiast. I like track days, autocross, and US Highway 129. I love aural pleasure.
    WitW 2013 || I UM
