#1
Bought a cartridge for it put in 3 cds and it work. Burned 3 took it out inserted tjem and put it back in said no cd. So reinserted orignal disk same thing. Have to manually extract cartridge as the eject button wont release. Any idea on fixes at all?
Sent from my Motorola Electrify using Tapatalk 2
infinity front,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, modded 225 exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,
#2
12v Installation Services: Audio, Alarms/Remote Starts, OEM Integration, etc.
Pioneer, Kenwood, Hertz, Audison, Rockford Fosgate
#3
If i had the money for that adapter i would
#4
Do these 6disks play burned disks?
#5
#6
Got a link to it?
#7
http://enfigcarstereo.com/AUDI_MLINK1_V1B.html
Boom, only thing is the stock cd changer cant' be used afterwards as it gets disconnected for this to work![]()
#8
Thanks fixed it and it does play burned disks.
#9
Ok second question po of the car had a line converter in hooked up to rear speakers it pinched a wire and poped a fuse back of radio.. now i have rhis poping coming from the rear speakers.. any one help please
#10
#11
Its consistent. And i only hear it coming from the speakers in the back seat. It dosnt seam to get louder as volune goes up and with volume all the way down its still their. Only time it isnt is when power is off. Again i did blow the radio fuse do to a pinched wire the ground out. Thats when ibstarted hearing the noise
#12
#13
So are those speakers in the rear seat lil subs or full range? If so can i just disconect them and add a amp?
#14
I not sure weather to replace amp or head unit
#15
#16
Ok.. i am thinking amp then. Do only rears and center tun on it or all?
#17
Bose or symphony?
#18
Audi concert
#19
