Results 1 to 3 of 3
Thread: No power to the rear wheels!
  1. Member VW Audi Man's Avatar
    Jan 27th, 2004
    Tampa FL.
    08-08-2012 02:46 PM #1
    I have a 2002 TT 225 and I am not getting any power to the rear wheels. Vag-Com shows no codes in either the Haldax or ABS so i was wondering if low fluid level could cause it to not turn on or if the Haldax motor is bad. Also I read that there is a fuse but it didn't say which one it is if anyone knows to check. Any thoughts? Thanks Adam
  2. Member VW Audi Man's Avatar
    Jan 27th, 2004
    Tampa FL.
    08-08-2012 05:17 PM #2
    so i pulled the Haldex oil plug and i **** you not 4 tables spoons of oil dripped out! I think i found the problem lol
  3. Member VW Audi Man's Avatar
    Jan 27th, 2004
    Tampa FL.
    08-09-2012 05:22 PM #3
    looks like the Pump for Haldex coupling V181 could be bad. Will have to run some tests and see i guess.
