Results 1 to 9 of 9
Thread: top wont close
  1. Member mr pibbs's Avatar
    May 13th, 2012
    Tampa, FL
    1990 Cabriolet, 1993 Honda Elite
    08-08-2012 03:05 PM #1
    Putting the basket case back in one peice - top wont close
    Finally got everything all where it should be.
    Oiled the pivot points
    Disconnected struts to make sure they were not stuck
    Top wont close - not even close. I can push it down, but it pops back up, and the gap between top and a pillar is too far for the j hooks. Top is also scewed right about a half inch.
    Trying not to get discouraged.
  2. Member BerryB's Avatar
    Jul 10th, 2012
    Milton
    85 cabriolet 16v
    08-08-2012 03:28 PM #2
    Mine does the same I just push my J hooks forward (right hand and pull down on the roof(left hand) when locking her down. Try even just sliding the handle forward a few mm by loosening the screws underneath and then tighten them back up while putting force in the direction needed. Hope my ****ty pictorial will help, mine does the same, but I have no problem "battening down the hatches"
    1
    2
    3
    4
    Had to do it all one handed(camera) but it takes some muscle to put my roof back up. I usually have to do it myself because my girlfriend isn't strong enough. Try just giving her **** and see what happens. My old boss used to say "if it doesn't work, smash it. If it still doesn't work; it wasn't worth keeping in the first place"
    *edit*
    added in a picture of my roof doing the same, I dont know about other cabbys i've never checked.
    I usually pick up the roof latch handles at any chance I can. They break of like they're getting paid to.
  3. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    08-08-2012 06:38 PM #3
    Roll the back windows down a couple of inches.
    New Tops need to stretch in the sun a bit.
    If you got the side cables too short that can happen too.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  4. Member mr pibbs's Avatar
    May 13th, 2012
    Tampa, FL
    08-08-2012 08:47 PM #4
    Quote Originally Posted by BerryB View Post
    I see what you are thinking, but my top is not that far forward. When I pull it down it is still an inch or more short.
    Quote Originally Posted by briano1234 View Post
    I have rolled the windows down.
    It's not a new top, just hasn' been on the car in months. Many months.
    I can't seem to locate the side cables. Would they be hiding somewhere?
  5. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    08-09-2012 10:06 AM #5
    Quote Originally Posted by mr pibbs View Post
    Well that is a convertible specialties top, I can tell by the stitching.
    The side cables run from the Teat, on the front frame, inside of the top, to the rear frame.
    If you run your finger on the back side of the rear frame, between the headliner and the top you will feel the finger that holds the tensioning spring., that the cable is attached to.
    You said, the top hasn't been on the car in "months?" then it has to re-stretch. Leave it in the direct sun light for a few hours, or in a closed garage with lights shining on the top. VW recommends putting the top up about every three days....
  6. Member mr pibbs's Avatar
    May 13th, 2012
    Tampa, FL
    08-09-2012 03:52 PM #6
    If I'm not mistaken it's an electrontop. I suppose your are right that this is an after-market replacement.
    I will let it stretch and check the side cables. Thanks for the help.
  7. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    08-09-2012 04:03 PM #7
    I had a experience with Convertible Specialties about 2 months ago, and for that reason that the side seam, which isn't heat sealed is just a singular stitch.
    On the outside at the top it isn't an issue to me, but at the rear corner, where the seam gets to the interior, I know that eventually the stitches will pull through at that spot and tear the material, and or allow water seepage into the interior. The rear cable seam was pretty rough and didn't have a finished look like they rushed it. So what with the seam, and the single stitched was a big no-no, and why I returned the top. It was a month longer to get, don't know why, and inferior to me product wise.
    I then ordered a topsonline, and they use ez-on, which is probably the cabrioworld type, and is flat seamed on the top, but the sides are embossed and heat sealed
  8. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    08-09-2012 04:29 PM #8
    When you say "the top has been off", what do you mean by that? The vinyl has been off, or the entire frame has been off the car?
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  9. Member mr pibbs's Avatar
    May 13th, 2012
    Tampa, FL
    08-09-2012 08:07 PM #9
    Quote Originally Posted by kamzcab86 View Post
    Frame has been off the car for a long time. I'm not sure how long, but at least a year.
