Well, the fronts will fit no problem, but they are going to sit well inside the fender well.
The rears, a 10" wide wheel, and a 55et will be really close on INNER clearance. And no way a 265 tire is going on there. if you are lowered you will NEED to stretch the tire assuming the inner wheel clears, which I have no idea if it will.. I am running a 9" wide et38 in the rear and it just barely pokes by like a 1mm.
That is a REALLY staggered setup, why so drastic? Honestly i think it will looks like crap unless you get a spacer up front thats like 15-20mm to even them out, and at that point why even run staggered.. Unless you like the look of the rears basically flish/poking slightly and the fronts sitting well inside the fender.
