Hi folks,
First, I would like to mention that I made my homework, I've read almost all threads up to page 7 that the search button gave me as results for the keyword «cam» in scirocco/technical vw/carbs-itb's and 8v engine forums.
I learned a lot, thanks.
So I made my mind on a cam swap, I'll probably go with the tt 268* for the drivability, along with a tri-y header.
However, I read that a bigger cam move the powerband upward in the rpm's, depending on how big the cam is…
My question is :
what is the interraction (if any) the cam will have on performance on an engine coupled to a short ratio tranny?
I don't know if it's clear (I'm no mechanics as you can understand): In other words, I have a AEN (8v short ratio) tranny on my carb'd 1987 Scirocco 1.8 8v, and it rev's up relatively fast. As an example I'm doing around 3350 rpm at 70 mph (205-50r15 tires 3.67 final and 0.89 5th; do your math, fun on sinuous country roads but pretty boring on the highway) and I wonder how it will do with a bigger cam.
I know I can move the powerband down in the rpm's with an adjustable cam gear (that I will get too), but will this turn a little power gain into a loss of time and money?
Another point is about the carb (a single down draft Pierburg 2e2). At full throttle, the second body opens up around 4000-4200 rpm IIRC, which gives an appreciated little humph. I understand that I should try to match the peak in the powerband with that sweet spot, right? But again, is this too low in rpm to give a noticeable gain (I’ve read about big cams that kicks off at 6-7k) ?
Am I right in my questions or totally wrong and cams just don’t give s*ht about trannys?
Any inputs appreciated.
Regards
