Results 1 to 4 of 4
Thread: Brake light
    Jun 9th, 2010
    Philly
    '89 Fox GL
    08-09-2012 03:14 AM #1
    Brake light in the dash keeps coming on when I get on the brakes. The new suspension I got for up front came with 10.1's, and ever since we put pressure back in the system it flashes the brake light at me. Does this indicate too much pressure in the system or something? They're doing a fine job of slowing the car down so I'm ignoring it for now. Anyone else had this issue?
  2. Member naterkane's Avatar
    Feb 8th, 2001
    Baltimore, MD
    Nothing all that street-able
    08-09-2012 03:20 AM #2
    It could have to do with a few things... did you adjust your hand brake cables?
    It's possible that your parking brake switch isn't working correctly.
    Also check your fluid level
    Best,
    Nater Kane
    http://limpithome.com
  3. Member j-boogie253's Avatar
    Nov 30th, 2009
    Tacoma, WA
    90 Fox, 91 Jetta, 98 A4 (RIP)
    08-09-2012 03:33 PM #3
    That light also comes on when the system is low on brake fluid so it may be an easy fix
    If you were a Volkswagen....who would your owner be?
  4. Member
    Jun 9th, 2010
    Philly
    '89 Fox GL
    08-13-2012 12:34 PM #4
    ^ Hopefully the case. Been concentrating on some other things, I'll check this out today though
