Results 1 to 20 of 20
Thread: Had wheels balanced for the second time and vibration still exists!?
  1. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    2011 Jetta TDI 6-spd
    08-09-2012 07:06 AM #1
    This is getting very annoying. I have 18 inch Karthoums with Goodyear Eagle GTs with decent tread on them still. Had them balanced on a regular machine and then just had them balanced on a road force balance machine and the vibration still exists. Car has 28,000 and is used for 90% highway driving. Any ideas here?
  2. 08-09-2012 09:04 AM #2
    Quote Originally Posted by tbone1989 View Post
    Are these the original wheels from new? Ive had a slight vibe issue on my GLI on 18" barthursts. Been back twice to have dealer rebalance and it won't go away. Its annoying. I wonder if the wheels aren't true...
  3. 08-09-2012 09:25 AM #3
    I can vouch for the same issue. (Steering Wheel Vibration)
    I just picked up a '12 SE and upgraded from stock to 18x8 235-40/18.
    I noticed a vibration at around 65 mph and went back and had the wheels and tires re-balanced.
    Now the same vibration still exists but has shifted to 60 mph and then tapers off when driving faster.
    I am still trying to figure out what is happening.
    Theory: the overall wheel/tire height has gone up by about 1/2" from stock. This will affect the camber ever so slightly. So maybe the camber is causing the vibration at those specific speeds.
    Anyone else has any insight?
  4. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    08-09-2012 09:26 AM #4
    I traded for these wheel with another forum member. The guy said he didn't put many miles on them and the tires drove fine. Im hoping for an issue with the tires and not something more serious. I plan on putting the stock 16's back on and seeing if the vibration is still there.
    Jul 30th, 2012
    Buffalo, NY
    MkVI 2.5 SE, RIP 1990 Jetta Wolfsburg
    08-09-2012 10:02 AM #5
    Do they need centering rings?
  6. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    08-09-2012 10:09 AM #6
    No, they are oem vw wheels, with center bore of 57.1
  7. Junior Member
    Dec 13th, 2008
    Chicago, Burbs
    '12 jetta se
    08-09-2012 10:41 AM #7
    For those that have had their wheels re-balanced. Did they use 2 wheel weights? or did they just use 1?
  8. Junior Member Maximilium's Avatar
    May 25th, 2012
    Chicago
    Jetta 2011 SE
    08-09-2012 10:47 AM #8
    I had a similar issue once, it turn out to be a damaged wheel.
  9. 08-09-2012 10:48 AM #9
    Quote Originally Posted by gti rt View Post
    I believe just one. why?
  10. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    08-09-2012 11:17 AM #10
    Quote Originally Posted by Maximilium View Post
    What did they use to determine that?
  11. Junior Member
    Oct 9th, 2011
    NY
    '12 GLI Autobahn DSG, '11 GTI DSG
    08-09-2012 12:15 PM #11
    I've had four cars with 18" oem vw wheels and the wheels on three of them, including my '12 GLI, become bent over time from hitting bumps and potholes. I think the metal is just soft and the low profile sidewalls provide little protection for the rims. The first time the dealer said the wheels needed to be straightened and that solved the problem in no time but it was $300 for two and it just happened again. Now I just live with it and drive as careful as I can... in a GLI.
  12. Junior Member
    Dec 13th, 2008
    Chicago, Burbs
    '12 jetta se
    08-10-2012 09:18 AM #12
    Quote Originally Posted by gemsky View Post
    To do a proper balance there should usually be 2 weights used. 1 on the outside and 1 on the inside. sometimes guys like to cheat and do a static balance and use 1 weight on the inside. this can cause vibrations at higher speeds.
    I've worked on plenty of vw's and audi's at work and have seen my fair share of bent rims. My bet though is its a bent front rim.
  13. Member King Schwab's Avatar
    Jul 7th, 2012
    Beaumont, TX
    2012 VW GLI
    08-10-2012 09:46 AM #13
    I have this same issue. Right at 65 I get speed wobbles. Im going back today to get a run out to see if there are any imperfections and to make sure they are using the correct cone when balancing. I've had the wheels balanced 5 times and yes I have hubcentric rings.
    John Handcock
  14. Junior Member Maximilium's Avatar
    May 25th, 2012
    Chicago
    Jetta 2011 SE
    08-10-2012 09:47 AM #14
    +1
  15. Junior Member
    Jul 26th, 2012
    Huntersville
    2013 CC/ 90 Corrado 16VT
    08-10-2012 10:06 AM #15
    + 2
    Bent wheel is almost an absolute. If you have balanced twice it is not likely that both time they were improperly balanced. Easy way to test remove wheels and put different ones on, or rotate wheels and see is the shimmy move to the back. Many times bent wheels on the back will be almost un noticable. Bent wheels can usually be reapired by any local wheel repair place.
    Hope this helps you resolve your issue
    Paul Barrett
    Coming soon www.DeutscheAutoParts.com save it in your favorites. VW and Audi parts at super discounted prices
    Also Check us out here
  16. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    08-12-2012 11:18 AM #16
    UPDATE: Had a different shop road force balance them. They are fine now, but wow. Talk about expensive.
  17. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    08-12-2012 01:14 PM #17
    +1
    Sent from my HTC_Amaze_4G using Tapatalk 2
    2012 MKVI Jetta GLI / 2008 Civic Si Sedan / 2007 Mazdaspeed 6 / 2004 MKIV Jetta GLI (1.8T) / 1996 MKIII Jetta GLX VR6
    https://twitter.com/Flyin18T
  18. Member tbone1989's Avatar
    Feb 9th, 2012
    NJ
    08-12-2012 01:26 PM #18
    Quote Originally Posted by Flyin18T View Post
    +1
    Well to avoid that ever happening, forged wheels are on my list.
  19. Member King Schwab's Avatar
    Jul 7th, 2012
    Beaumont, TX
    2012 VW GLI
    08-14-2012 08:22 PM #19
    Had wheels balanced on a Hunter Roadforce. Problem solved. Seems strange the older model worked better than the new laser guided high speed balancer.
    John Handcock
  20. Member
    Oct 1st, 2007
    Atlanta
    '13 GLI Autobahn
    08-14-2012 08:28 PM #20
    This has happened to me before, and it turned out to be cupped tires.
    It does help to go to a good shop though. You get what you pay for. Balancing is an art.
