Results 1 to 13 of 13
Thread: TDI/2.0 Build Questions
  1. 08-09-2012 09:05 AM #1
    What's up vortex. Got some quick questions. I'm doing a little project with my mk3 at the shop and I came across a build that I wanted to try. Basically I have found out that the turbo manifold and turbo charger from the TDI bolts on. Now I am aware that the TDI turbo only works at lower RPM's but I am only trying to build a fun daily, not a monster (yet, I'll be doing that with my VR6).
    What I want to know what are the risks (if there are any) of running this build? Will using the TDI turbocharger and manifold on my motor cause anything to go wrong? What do I need to know?
    And the parts that I need for this build are the turbo charger, manifold, oil lines, g60 injectors, intercooler, and fuel regulator pump. If I am missing anything please let me know. Thank you guys!
  2. 08-09-2012 10:04 AM #2
    TDI turbo on 2.0 ABA = good torque up to 3500rpms, then it runs out of breath and you're left hanging with a very weak 3501rpm-redline.
    Hope your clutch and trans aren't beat already because they soon will be.
  3. 08-09-2012 04:17 PM #3
    I figured the Turbo would only work at low rpms, but why would did you mention the trans
    and clutch? I know that turbos put more strain on.the motor, but is there something about this.build.that would.cause it to wear down the trans and clutch quicker?
  4. Member tykiers's Avatar
    Nov 12th, 2009
    wainfleet
    '95 vw golf sport 2.0L, 94 diesel 4 door golf(parts car), 95 vr6 passat, 97gti vr6
    08-09-2012 05:42 PM #4
    depends on how you drive...
  5. 08-09-2012 07:11 PM #5
    Quote Originally Posted by tykiers View Post
    This is my daily that I am doing this build with, so that means the fastest that I would be driving is around 80mph on the highway.
  6. Member jstn's Avatar
    Jun 18th, 2008
    boston, ma
    '97 tdi/ahu, '05.5 tdi/brm
    08-09-2012 09:05 PM #6
    the stock ahu turbo (gt-15) is a waste. go with a vnt-17 instead. the vnt spools faster and will handle a bit more mid/high rpm boost for a gasser.
    i think this turbo will bolt up, but don't quote me.
    http://www.idparts.com/catalog/produ...roducts_id=541
    justin
    '97 TDI | Boston Hydraulic & Machine Inc - Since 1950 | Volkshore.net
    "Hey guys. Woah, Big Gulps, huh? All right! Well, see ya later!"
  7. 08-10-2012 02:51 AM #7
    Thnaks jstn. That was going to be my next.question.
  8. Member Stealth_TDI's Avatar
    Nov 11th, 2003
    Newport News, VA
    1998 Jetta TDI, 2003 Passat GLS
    08-10-2012 08:27 AM #8
    Hello,
    Quote Originally Posted by jstn View Post
    the stock ahu turbo (gt-15) is a waste. go with a vnt-17 instead. the vnt spools faster and will handle a bit more mid/high rpm boost for a gasser. i think this turbo will bolt up, but don't quote me. http://www.idparts.com/catalog/produ...roducts_id=541
    That's not quite a bolt-on affair. Most VNT turbos will hit the rear engine mount unless it's been modified. The only VNT-17 I've seen clear the rear mount is the two-piece unit made for the B5.5 Passat.
    I've been considering a VNT-17/22 swap for a while. But I also have my eyes on IDParts' GT2052. Either swap will require exhaust work. But the GT2052 won't require VNT conversion or a special program. I could probably run it without a new tune at all. I KNOW I can at least drive it until I get the tune. A VNT NEEDS a tune.
    A true bolt-on option to consider is a K03/K04 hybrid from BoraParts.com. With the right tune, exhaust and injectors, I've seen one spin 149-whp and 312-lb/ft (dyno-dependent, right?). It also ran 14.7 @ 93-mph in the 1/4-mile. I've only managed to get 136-whp and 263-lb/ft. My best 1/4 was 15.3 @ 89-mph. I think I can do better with the GT2052.
    Scott
  9. Member jstn's Avatar
    Jun 18th, 2008
    boston, ma
    08-10-2012 09:04 AM #9
    Scott this is for a 2.0 gasser so I'm absolving myself of any knowledge related to interoperability of parts and components... however your observations are correct.
    BTW, I'm going with the BHW mani and the gtb1752vk on my mk3. The swap starts soon!
    justin
  10. Member MYGTI_MA's Avatar
    May 3rd, 2010
    North of Boston
    1997 GTI 2.0 // 1983 Rabbit Diesel
    08-10-2012 10:39 AM #10
    justin
    pics or it isn't happening.
  11. Member jstn's Avatar
    Jun 18th, 2008
    boston, ma
    08-10-2012 10:42 AM #11
    Quote Originally Posted by MYGTI_MA View Post
    26psi tune until i get an 11mm pump and then 30psi. goal is 200whp but we'll see...
  12. 08-10-2012 11:42 AM #12
    Quote Originally Posted by smittywerb View Post
    Well, think about it. You're building the motor to run 50-60% more torque on a low boost setting through a clutch/trans that was originally running only 123 lbs/ft. And this increase comes on, basically, off-idle instead of gradually/later in your rpm curve. I sincerely hope you upgrade your clutch at least.
  13. 08-10-2012 11:54 AM #13
    Quote Originally Posted by 911_fan View Post
    Oh definitely, I'd be an idiot if I didn't.
