Results 1 to 23 of 23
Thread: Next Audi RS3 undisguised, shows us interior
  1. 08-09-2012 09:47 AM #1
  2. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-09-2012 12:03 PM #2
    You may want to edit that - it's the S3, not RS3.
  3. 08-09-2012 01:43 PM #3
    Obviously it won't be what we see here in North America, especially the dash.
    As well disappointed with the 280hp 2.0L.
    However I will let it slide if Audi places a reasonable sticker price on this.
    Shouldn't have a problem keeping it under $45k US or $50k Cdn
    **Also hope they bring this out soon, more so the S3. I almost bought a 8P a month ago but backed out since it didn't make sense, just so I can get my 'fix'
    Waiting : 2015 Audi A3 2.0TFSI /w Quattro S-Tronic and S-Line
    Current : 2010 Genesis Coupe 2.0T
    Previous : 2001 Audi S4
  4. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-09-2012 01:52 PM #4
    The US won't be getting the three door, that is correct. We'll get the sedan body style.
    That said, the dash should be virtually identical in the US spec models.
  5. 08-09-2012 02:02 PM #5
    Quote Originally Posted by Travis Grundke View Post
    I could have sworn I read somewhere the US market will get a new dash with higher grade materials. The 8P A3 is a Jetta with a big price tag
  6. Member
    Jul 30th, 2008
    NYC
    08-09-2012 06:10 PM #6
    280hp in a S3 is lagging behind the times. Ever since turbocharging became popular, low end brands like Ford, GM and Hyundai are cranking out mega powered 2.0T engines on their low end cars. Need to take it to the next level.
  7. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 08:03 AM #7
    Quote Originally Posted by Rudy_H View Post
    I may have read the same thing as well, but from the press reviews I've read the new MQB dash does have soft-touch materials galore already so I'm not sure how much would actually change for the US market. George saw one a few weeks back - maybe he could provide some more thoughts on the interior from there.
    My understanding is that the dash layout will remain the same for the US.
  8. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 08:08 AM #8
    Quote Originally Posted by LWNY View Post
    Depends on what your goal for the product is. Audi's stated goal with its vehicle development programs moving forward is to reduce mass and improve fuel efficiency. If you recall a few years ago Audi demonstrated an S5 coupe in production guise using advanced materials to save weight. It ran a stock 2.0T that turned better numbers than the V8 in the S5 at the time.
    Same goes for the new GTI. The rumor mill is telling folks it's going to get 260-280hp in the MQB version, but I'm placing my money on 225-230hp so there is room for an R model in the 260-280 range. If VAG can continue to reduce the weight of these vehicles then there is not as much need to keep cranking the horsepower.
  9. Member dmorrow's Avatar
    Jun 9th, 2000
    Cincinnati, OH
    '06 Audi A3, '06 BMW Z4M Coupe
    08-10-2012 08:33 AM #9
    With the same models in Europe costing more than here I can't see why the US market would get something better than Europe. I don't think VW/Audi has ever had better anything sent to the U.S. over the European version.
    You also have to remember that the dash for the 8P came from it's release in 2003.
  10. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 09:21 AM #10
    Quote Originally Posted by dmorrow View Post
    Keep in mind that besides weight savings, the other major goal of the MQB program was to significantly reduce manufacturing time and to amortize more costs across more vehicles. Translation = lower total cost to build. My guess is that this is going to provide some much needed wiggle room to provide additional options and enhanced features that we in North America did not have access to during the 8P cycle. The 8P A3, like the Golf V it is essentially based upon, was a very expensive platform to build. While the Golf received a significant refresh that cut build time and costs by something like 30% the A3 did not receive a similar program - one of the other reasons why the 8P had such a long life (to recoup costs).
    No, my guess is that we will have a virtually identical interior to the Eurospec model already in production. The questions that remain for US release are all related to powertrain and option packages. Many of us are holding out for a six-speed manual with quattro, which I would expect we'll get with the S3 - but whether that will be an option on the regular spec A3 is a different story.
  11. 08-10-2012 10:17 AM #11
    In the end, I think all I care is the speculation that the likely US bound sedan will be released at the Paris Show
    29 Sep 2012 - 14 Oct 2012
    That's when I think all the questions will be answered, well likely this month / next leaks will start popping up. lol soon
    Back to the S3 posted above. Again, North America won't see the 3-door for a bit. Realistically though, without upgrading the turbo, and the weight that the S3 will likely be, it becomes a pissing contest.
    What I mean is, 300-350 whp and the lbs-ft a 2.0L engine will provide you, matted to Quattro I think this car will be enough for my personal needs anyway.
    Right now I have my Genesis Coupe putting down ~ 250 whp and about 320 wlbs-ft, that's with a TD04 which in BW terms is a tad larger K03. Torque wise, this is PLENTY, and the rear wheels break out quite easily. I wish it had a bit more top end, and I think 300 whp would be fine.
    With the K04, I think with all that is being put into the 2.0T (TFSI?) the weight we should likely expect in around 3,200 lbs, Quattro...even if it is matted to a DSG...MAYBE we will be blessed with twin scroll technology to make that bottom end even more fun!!
    ECU tune, intercooler, tbe = stage II *we will see what fuelling is required* - for a daily driver, you will have PLENTY of car. At my age, and the rules now where I live, I am getting over the fact that I will likely not see a 2.5T in my near future, I will just buy the sound track for the stereo
    ***here in Ontario where I live, 50 km/h means a crushed car, $10,000 fine and your license gone for a year. Right now, 100 - 150 km/h gets up there in under 3 seconds when you want to pass someone. There is a point where things get excessive.
  12. 08-10-2012 11:59 AM #12
    My guess is that this is going to provide some much needed wiggle room to provide additional options and enhanced features that we in North America did not have access to during the 8P cycle. .
    nice if they could wiggle something into the engine compartment to compete with the 135, but we get the pop up screen and a groovy infotainment system
  13. Member
    Jul 30th, 2008
    NYC
    08-10-2012 03:44 PM #13
    There is not much less weight they can reduce, since only the 1.4T and 1.8T got some serious redesign/weight reduction program, not the 2.0T. What the need is DSG with some super low takeoff gear like all the 8/9 speed slushboxes that allows low HP engine to have fast accelerations.
  14. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 04:00 PM #14
    While I'm hoping we get information at Paris, it sounds like that show is going to be reserved for the S3, the Sportback, or if we're lucky - both. Everything I've read points to the A3 sedan being announced in November-December-January, but I'll be happy to be wrong.
    As for 300-350hp - you'll likely need to wait for an RS3. I'll wager big bucks on the S3 not putting down anything above 260-280hp.
  15. 08-10-2012 04:00 PM #15
    What's going on with the rear valance/dual exhaust, the final valance wasn't ready for the dual exhaust?
    And the wheelbase for the 3-door would be identical to the 5-door (regardless of the mqb's potential for differing wheelbases)?
  16. Member BeBop!'s Avatar
    Jun 18th, 2009
    MN
    2006 Passat 2.0T
    08-10-2012 04:27 PM #16
    Why doesn't Audi understand that we don't need another sedan on the market? They have the A4 for that. The A3 should be only sold as a 3 door and sportback. \end rant.
  17. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 06:27 PM #17
    Quote Originally Posted by Chimera View Post
    Sportback is supposed to ride on a slightly lengthened wheelbase. Not sure about the sedan, but I would imagine it will be the same wheelbase as the Sportback. This is one of the advantages of MQB - it allows this kind of scaling at a significantly lower price point.
  18. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-10-2012 06:32 PM #18
    Quote Originally Posted by BeBop! View Post
    Because that's what sells primarily in the US and China: sedans. That, and the fact that the A4 has grown to A6 proportions and there is now room for a smaller vehicle to fill the niche.
    I think that a lot of people forget that Audi has discovered that the traditional sales model based on vehicle size correlating to price point doesn't really work any longer. Vehicles have become more lifestyle and manufacturers can tune the vehicles to different markets. So, the A4 is much more conservative, mainstream, and plush. That doesn't mean that there isn't a market for a slightly smaller, sportier themed, more avant garde model that wouldn't appeal to a slightly different buyer (think A5 Sportback, A7, or in some ways the upcoming A3 sedan).
  19. Member GTI2Slow's Avatar
    Jun 22nd, 2007
    New Hampshire
    MK5 GTI, 2013 Escape Ecoboost 1.6 4WD
    08-10-2012 06:38 PM #19
    I am looking forward to the A3 sedan, a smaller sporty sedan seems like the next step for me. The A3 has always seemed like a upmarket GTI.
  20. Junior Member
    Jan 11th, 2012
    KCMO
    2011 BMW 135i
    08-11-2012 08:49 AM #20
    Agree. I'm thinking the first time we see the sedan in public is, at the earliest, the Los Angeles Auto Show, November 30-December 9. Timing is right.
    I've been thinking about how many smaller/sporty/premier models are being released in the next year or so from the German brands. The Mercedes CLA sedan based on the CLA Concept, the BMW X1- which is just arriving at US dealers now, an updated 1-series coupe (likely to be badged as a "2-series") with the single twin-scroll turbo 240 hp 4 cyl available in the base model. It makes for some great choices for consumers.
    Right now I'm interested in something that has awd- it's just a real pain and expense to switch out to winter tires every November. The A3 sedan could be my pick if they get the engine right.
    I believe that the whole base engine thinking is radically changing to giving consumers an uptick in power. Seems to me it's crucial in getting the parameters right of what is basically a new niche automobile for the North American market.
  21. Member Travis Grundke's Avatar
    May 26th, 1999
    Cleveland, Ohio
    2006 A3 Sport 6MT
    08-11-2012 11:27 AM #21
    Quote Originally Posted by brookside View Post
    I also wonder how much Audi is pushing up timetables for some of the international launches considering the economic slowdown in Europe. I've read from a few sources that they stepped up the actual on-market / delivery timeline for the MQB A3 by ~6 weeks outside of Germany, specifically to the UK and they're looking to ramp the Sportback and S3 sooner than expected. Same goes for the MQB Golf which is now slated for reveal on September 4 in Berlin with sales to start in November instead of the originally planned January.
    This can mean one of two things: the timetable for the sedan has been pushed up for US on-sale dates, or pushed back to accomodate the European market introductions. Either way we should know more by November. My hope is that the US on-sale date is May of next year.
    My hope for powertrains is that we get the newly updated 2.0T (debuts in the '13 Q5 this fall) in lieu of the 1.8T and a manual transmission. Ideally we get a manually with quattro, but again if I were a betting man I would say that we'll only see the 6MT+quattro combination in the S3 and there may even be a really good chance that the standard A3 only gets the DSG gearbox here in the US. I'm hoping to be pleasantly surprised.
  22. Member
    Jul 30th, 2008
    NYC
    08-12-2012 01:56 AM #22
    Audi's redesign of the 2.0T for a longitudinal layout doesn't mean it will appear in their longitudinal lineup. The last 2.0T for the A4/A5/Q5, etc has not even been dropped in any transverse layout platform yet. Not sure if it will ever happen.
  23. 08-13-2012 09:04 AM #23
    Sorry *edit
    I don't expect Audi to get me 300-350hp, APR or GIAC will get me there, along with the help of a few of our happy vendors
