B5.5 Wagon btw on K-sports so it can get low.
#1
Was thinking of doing et25 all around and space accordingly then run 225/35/19's of some small variety like nitto neo gen, federal 595 or achilles str.
I know SaltyD did it but that was back in non-low balloon tires days.
card carrying autocrat.
my sofa pulls out, but I don't.
#2
#3
I'm running 19x9.5 et40 with 235/35s sitting pretty low on my W8
Tires clear everything fine, but inside lip of the wheel is pretty close to the spindle, and rear upper strut mount (4mo).
\\_\__\___http://lowdownlabs.com/ ___/__/_//
Passat W8 Sport 6 speed manual
ST Coilovers | Miro 111 19x9.5 | Achilles ATR Sport 235 35 19 | COAM
SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
#4
Better shot showing fitment
I think a 19x10 et25 would have an unnecessarily low offset. A 19x10 et 30 should give you plenty of inside room I'd think (comparing to what I've got) and unless you want that crazy stretch look, I think a 235/35 would be better suited than 225 (I've got achilles atr sports btw)
#5
perfect, lowest et it is.
#6
so how low could you really go on 19s without actually starting to break the axles and other stuff on the car
im planning on lowering mine on 19x8.5 real soon
#7
#8
and as evidenced by my strut towers you'll put the upper arms into them before you bottom as well.
#9
I was at 24" FTG with stock wheels, going 19s raised the car a tad, so I dropped it down another half an inch. I think I'm about 3" lower than stock now (if I remember correctly). I busted one aftermarket axle (inner joint came apart) and that was with stock wheels at 24", but haven't had any problems after (knock on wood). But yes, my upper control arms have hit the top of the wheel wells.
