I am surprised there is no DIY for this in the sticky.
swapping to a perforated one with silver stitching to match the DSG knob i have. sure it is a pretty easy swap, just wondered if anybody had pulled one off. i have an 09 a3
waiting for TP...my memory is shot.
I think you pull it forward a bit, then you insert a small flathead screwdriver...either in the front or rear of the top portion...then it comes off.
722 pages, 25255 posts, and 1,015,739 views later... R.I.P. LoL Bump thread 03/27/2008 ~ 02/16/2011.
Link to my build: Audi A3 3.2 VR6 BT
VMR l Wheels - V721
yea u need to pull it up.
then stick a needle or thin flat head inside from the back
then u release clip
then pull forward.
hirro
ok i have look at it pretty closely. there is a small hole in the back about 1 cm down from the top. i have stuck a pick/small driver in there and can't seem to find anything to slide/push/life. looking at the replacement there is a metal clip that looks like it snaps down onto a latch once installed.....so figuring i have to get that latch down/out of the way to release the OEM cover??
ok, got it. thanks. under the cover is a metal "barrel". looks a bit like a gun barrel, with the "sight end" at the back side away from the button. the little clip on the cover snaps over the "sight notch".
so just a slide of a very small common screwdriver does the trick.
it clips in. just unclip it either push up towards top or push down. I forget which.
hirro
Once you get new handle and see how it works it will make perfect sense.
this should suffice for the idea in mind.. http://www.audizine.com/forum/showth...handle-install
#11
#12
VMR l Wheels - V721
