Results 1 to 13 of 13
Thread: Maestro logs
  1. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-09-2012 04:58 PM #1
    Hey guys, i was the one of the people earlier who were having surging issues. I believe i have it under control for the most part now after tinkering with my EBC to slow down the onset of the boost. You will see a little bit of it in my WOT logs.
    the setup:
    Tial GT3076r .63
    2.5 hotside, 3" cold side
    50mm (i believe) Tial BOV, 38mm tial WG
    007 intake manifold with 80mm TB on a built AEB, stock cams
    1000cc injectors, 255lph in tank and 255lph inline. Aeromotive adjustable FPR
    I was hoping maybe someone could take a look at my logs and tell me what they think
    Here's a cold start log.
    https://docs.google.com/spreadsheet/...ERkVRN3c#gid=0
    Here's a bit of city driving shortly after that cold start (on my way to work, fairly cool temperatures)
    https://docs.google.com/spreadsheet/...5VFBSSXc#gid=0
    Here's 2 WOTs. one of them i went from 3rd to 4th.
    https://docs.google.com/spreadsheet/...xQUUyMHc#gid=0
    https://docs.google.com/spreadsheet/...FaXFjNmc#gid=0
    This last one is a new issue ive developed. It's weird, if im coming to a rolling stop and i pop it into neutral the rpms will dip down way past my idle (900ish) and stall out. Other times it'll dip to the same level then recover and shoot back up to like 1500rpm and settle at 900rpm. This log here shows it dying. Any ideas? It's getting old fast. No changes to hardware or software before this happened.
    https://docs.google.com/spreadsheet/...zlGZUtjWkFkUHc
    Thanks in advance.
  2. 08-09-2012 05:09 PM #2
    Use Google Docs
  3. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-09-2012 05:21 PM #3
    how do i do that? do i have to individually add each value?
  4. 08-09-2012 05:23 PM #4
    Use your Google account to upload the logs.
  5. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-09-2012 05:32 PM #5
    ok, done, thanks for that.
  6. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-09-2012 08:50 PM #6
    He he nobody?
    Sent from my Galaxy Nexus using Tapatalk 2
  7. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-10-2012 09:48 AM #7
    bump
  8. Member velocity196's Avatar
    Feb 19th, 2006
    Washington
    2006 MK4 GTI, 2012 Golf R
    08-10-2012 03:32 PM #8
    Just a quick look of the first WOT. Its a hair lean on the first log. .82 lambda is 12/1. Its OK I guess but more people would rather see at least in the 11's a hair.
    Al
  9. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    08-10-2012 04:03 PM #9
    Your AFR seems to wander a bit. I'd ensure that you don't have any exhaust leaks.
    Your Boost request has a really weird dip in it even though your foot was to the floor. I wonder if something's going on that's causing the programming to want to steal boost from you.
    Holy crap your boost hits like a freight train!
    http://dl.dropbox.com/u/9842192/Methadone/wotpull2.xls
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  10. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-10-2012 04:50 PM #10
    Thanks for your input guys. Are there any other logs I can do to see what's going on to make boost act like that? I've been playing with my ebc to try and slow down the onset of boost iny attempts to fight compressor surge
  11. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    08-10-2012 06:02 PM #11
    Quote Originally Posted by methadone View Post
    Seafoam test for exhaust leaks.
    My Build
  12. Member methadone's Avatar
    Mar 31st, 2005
    Toronto, Canada
    08-10-2012 08:29 PM #12
    will do that tomorrow and report back with findings (if any) and another 4th gear WOT pull.
    thanks
  13. Member velocity196's Avatar
    Feb 19th, 2006
    Washington
    08-11-2012 12:14 AM #13
    thanks
    I prefer logging manually myself. Sometime I use the maestro logger but in blocks 3, 20, and 31 all the info you need for checking a WOT pass. Unless your diagnosing a problem between those 3 you get rpm, throttle angle, ignition timing, maf if being used, knock in all 4 cyls, and fuel requested and actual. Pretty much all you need unless diagnosing issues. Cheers
