Results 1 to 12 of 12
Thread: Alignment Question
  1. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    2010 CC 2.0T 6 Spd, 2007 GMC Yukon Denali 6.2L V8 AWD Hers
    08-09-2012 06:36 PM #1
    So I had new tires thrown in a week ago. Took her in for the alignment. They said everything is kosher. I was looking at the back of the cc today. It looks like the rear squats. Like the camber is out and makes the outside of the tires poke out. So the tires are riding on the inside of the tire a little bit. Is this VW spec. Anyone notice. I guess that's the way the VW rides. Any thoughts. TIA.
    2010 CC 2.0T 6 Speed Manual, White Gold,De-badged, Euro Headlight Switch, Rear Fog Lights, 6000k HID Headlights and Fogs, 35% Tint, 50% Tint on Windshield, 3M Clear Bra Paint Protection, Clear Turns.
    May 1st, 2012
    Kansas city
    2009 VR6 4 Motion LBM - 2000 Audi S4 Sponsored
    08-09-2012 07:53 PM #2
    They should be pretty close to true on the stock setup. You can check by throwing a level on it or better yet download a bubble app and stick a piece of wood on two flush point on the time. Then use the app to see how many degrees it's off. A little camber is desirable. Mine are off a degree but I'm on eibachs however my squat is minor when you look at it.
  3. Member Bthasht's Avatar
    Oct 6th, 2011
    757 VA
    2009 VW CC
    08-09-2012 08:05 PM #3
    I run-2.5° in my rear, but I'm real low on coils. All cars have negative camber in the rear stock to counter balance the car. My guess is vw set it at something like -.8 or so?
    Sent from the tip of my fingers using tapatalk
  4. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    08-10-2012 08:41 AM #4
    Ok. Thanks. I did check it. Passenger side was -1.9 and drivers side was -1.4. In the rear. Guess I'll take it back it.
    May 1st, 2012
    Kansas city
    08-10-2012 10:15 AM #5
    That's excessive for OEM and out of spec on the 1.9 side.
  6. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    08-10-2012 01:54 PM #6
    Yea. Going to take it back to the dealership. It's not right.
    Sent from my iPad using Tapatalk
  7. Member Bthasht's Avatar
    Oct 6th, 2011
    757 VA
    2009 VW CC
    08-10-2012 01:57 PM #7
    The cc it's not camber adjustable...correct?
    Well maybe the rear a little
    May 30th, 2008
    NJ
    08-10-2012 03:44 PM #8
    Quote Originally Posted by Bthasht View Post
    The rear is adjustable, nothing CRAZY, but adjustable.. the front is not.
  9. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    08-11-2012 07:21 AM #9
    Quote Originally Posted by cook0066 View Post
    It should be in the -1.2 range or something like that
    And tell them you want the camber equal on both sides too in the rear
    2013 VW
  10. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    08-11-2012 07:26 AM #10
    Ok. It's going back on Monday.
  11. Member cook0066's Avatar
    Apr 13th, 2010
    Durham,NC
    08-14-2012 06:48 PM #11
    Didn't get a chance to take it in. It will be at home for the next 2 weeks. Wife and I are headed to the beach house for 2 weeks. We drive the Big car. I will take it in when I get back.
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    08-14-2012 11:14 PM #12
    VW uses degrees, minutes & seconds for the alignment specs.
    so 1 degree, 20 minutes plus/minus 30 seconds = 1.33 degrees plus/minus .0083
    1 degree, 45 minutes, plus/minus 30 seconds = 1.75 degrees (sport suspension... that should be on the CC)
    all depends on the PR-G## number for the alignment specification
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
