Results 1 to 4 of 4
Thread: 09 VW CC belt tensioner
  1. 08-09-2012 08:53 PM #1
    Hi All,
    I'm hoping someone can help me. My serpentine belt snapped the other day while driving. I picked up a new belt today, but for the life of me can't figure out how to loosen the belt tensioner. I would appreciate any advice with picture if possible.
    Thanks
  2. 10-02-2012 12:10 PM #2
    Quote Originally Posted by lightspdcc View Post
    Hi All,
    Thanks
    somebody please help this man.. i need help too
    Dec 1st, 2009
    2010 CC 2.0T 6spd, 2012 CC Lux+ DSG, 2001 Corvette 6spd Z51
    10-02-2012 01:48 PM #3
    These belt tensioners are typically spring-loaded. There should be a hole on the tensioner, where you can insert a 1/2 inch square socket-drive, or an allen key, which is used to rotate the tensioner against the spring, so you can slip the belt on, and then slowly release the spring tension against the new belt.
  4. 10-09-2012 01:57 AM #4
    Should be a 16 mm wrench turning it clockwise when looking at the engine in front of you.
