Results 1 to 12 of 12
Thread: EPC + ESP (on) + Gas pedal not responding...
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-09-2012 10:36 PM #1
    After installing my TBE, i probably grounded my o2 sensors which for what i have read it fried my ECU...
    I got the following codes:
    00532 Supply Voltage
    01314 Engine Control Unit
    17501 p1173 Angel Sensor 2 for throttle valve drive-g108: Signal too High
    p1634 accelerator pedal position sensor 2-g185: Signal too High
    18039.p1631 throttle body position sensor switch -C- Circuit:
    From all i have reviewed and read i guess i did burn my ECU/ECM... now my question is how expensive is this part?
    I have a 2004 1.8t GLI blue lagoon so idk if its 2004 or 2004.5 (sorry im not that aware if they have a different ecu/ecm)...
    I know for fact ill have to change my o2 sensors to make sure and maybe change the o2 wiring harness. which will be around a total of 220$
    but then ECU... Any input? on good ebay ecu's or something?
    Thank you, Andres
  2. Member rbuicki's Avatar
    Jan 21st, 2012
    Irvine, California
    2002 Jetta 1.8t (sold) 2003 GTI 24v
    08-09-2012 11:22 PM #2
    F*cked up ecu 100%.
    Find one on ebay or the junkyard with the same part number, and then you need to have the immobilizer defeated so you can actually start your car when you put the new one in.
    Good luck
  3. Member GLI-R's Avatar
    Dec 1st, 2011
    Puebla, Pue. Mexico
    Rolling Thunder
    08-09-2012 11:36 PM #3
    You ECU is done... like screwed up for real
    Get a new one
    Good Luck
    -2011 MK4.5 1.8T VW Motorsport GLI R Proyect. Codename ".:Rolling Thunder"
    -"The ammount of Love, Money and HorsePower We Can Have Is Never Enough" -Sensei Mawy Luna
  4. Member
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-10-2012 08:46 AM #4
    Quote Originally Posted by GLI-R View Post
    Get a new one
    Good Luck
    thx for the replies guys!!! so 200% sure is ecu? i hope the tb is okay
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-10-2012 09:10 AM #5
    btw does anyone know why in the world theres oil in my o2 sensor connectors??? (both of them) ??? did my turbo go out too? lol
  6. Member GLI-R's Avatar
    Dec 1st, 2011
    Puebla, Pue. Mexico
    Rolling Thunder
    08-10-2012 11:14 AM #6
    Quote Originally Posted by ukyvakrow View Post
    Geezus man
    that would be either the piston rings or the turbo itself
    Time for new rings and/or FrankenTurbo!
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-10-2012 11:23 AM #7
    Geezus man
    Like the thing is... i didnt see any oil in my turbo or nothing when i was doing my tbe, and i didnt see any oil what so ever... but when i took out the o2 sensors wiring from the black box and disconnected it 4 - 5 drops of oil came out. -.-
  8. Member GLI-R's Avatar
    Dec 1st, 2011
    Puebla, Pue. Mexico
    Rolling Thunder
    08-10-2012 11:25 AM #8
    Does your car blows blue smoke when driving around?
    Are you sure that what dropped out of the sensors was not water full of exhaust carbon?
  9. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    08-10-2012 11:32 AM #9
    check the plug that attaches to the throttle body, mine was loose and I was having similar symptoms and codes... I thought it was the ecu until I was that and replaced the plug with one that clipped on correctly
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  10. Member
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-10-2012 11:45 AM #10
    Quote Originally Posted by mk4boost View Post
    here is the thing, I installed TBE from 42dd Saturday. that same night i took it out for a good 40 mile drive, the car was fine except some rattling which I was going to fix the next morning.
    I went and next morning I turned the car on and had the EPC + ESP light + CEL went up. Rough idle from 900 - 1200 rpm and a unresponsive gas pedal.
    after trying many things i took out the TB and the sensor right next to it. Cleaned them real nice and carefully the thing looked nice just some carbon on it.
    when installed it i turned it on and the same lights... went up. and as before same iddle and the car is running rich which i guess its because its on total LIMB mode.
    I dont wanna start buying parts without knowing what went wrong. cuz if i burn another ECU i might as well burn the car
  11. Member
    Mar 4th, 2012
    Orlando, Fl
    04.5 GLI 1.8T
    08-10-2012 04:47 PM #11
    anyone ? plz
  12. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    08-14-2012 08:31 AM #12
    i would re post this in the 1.8t forum for some better technical advise man
