Results 1 to 10 of 10
Thread: aba having slight idling issues/occasional stalling
  1. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    08-09-2012 11:00 PM #1
    Mk2 golf w aba motor and today while driving home when I'd pull up to a light or come to a stop, after pressing the clutch the rpm's shoot down to almost stalling (twice it stalled) then shoots back up to normal. I searched and found a lot on the icv.
    but before i get into that another slight problem is earlier i was driving and while staying at a steady speed, not accelerating, it seemed to "bog" down slightly, or sputter almost but hardly noticeable.
    I feel like this could also be a vacuum leak, will look more into this weekend. It seems more of an inconvenience than a major problem but I need to figure it out nonetheless.
  2. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    08-09-2012 11:24 PM #2
    Last time a tune-up was done? Or even the gap on the plugs checked?
    FS:Sunroof Deflector
  3. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    08-09-2012 11:48 PM #3
    not sure, i bought it last saturday as is and the problem occured today. didnt register it until last tuesday so this weekend was when i planned on getting into it, including tune up.
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    08-10-2012 10:52 PM #4
    OBDI or OBDII setup?
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  5. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    08-11-2012 06:11 PM #5
    obd1
  6. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    08-17-2012 07:06 PM #6
    BUMP
    Cleaned throttle body and ICV with carb cleaner and sprayed it down with wd-40 and it made no difference with how it idles, haven't driven it yet. I sprayed down all the air stuff with carb cleaner looking for any vacuum leaks and no change in idle either.
    Any other ideas of what it could be? Again, the rpms drop super low (under 10 grand) when I push the clutch and occasionally it drops so low it stalls. Also while accelerating and shifting up it'll hold bog out slightly then jump back to normal rpm range.
  7. Junior Member 16vjettagl's Avatar
    Dec 14th, 2009
    Madison, VA
    95 jetta gl(sold), 04 .:R, 09 tiguan
    08-18-2012 08:54 PM #7
    The ABA motor should idle around 900 rpms. And have you done a tune up and you might want to try adjusting the idle stop on the TB. I had to do the some thing on my jetta. And if all of that does not work then try the TPS.
  8. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    08-18-2012 11:49 PM #8
    Tune up is due and I'm going to tomorrow, hopefully that will help. When I cleaned out the ICV and tb both we're still pretty clean so I don't think either is the problem but I'll look into the idle itself.
    Thank you and will be back if I need more help
  9. Member Kjkustomz's Avatar
    Apr 10th, 2011
    Edmonton AB. Canada
    99Wolfburg golf 8VT, 79 German rabbit 16vt aba/abf
    09-20-2012 04:49 AM #9
    Unplug your maf & see if ur issue goes away. If it does your maf needs replacing.
  10. Junior Member
    Sep 22nd, 2010
    Ocean County NJ
    1988 VW Golf
    10-07-2012 04:43 AM #10
    new spark plugs did the trick, i haven't had the problem at all since I replaced them.
