VWVortex.com - Which of these cams should I use for 1995 Jetta Turbo ABA
    Results 1 to 8 of 8
    Thread: Which of these cams should I use for 1995 Jetta Turbo ABA
    1. 08-10-2012 01:23 AM #1
      I am looking at getting a Autotech 260 or 270 for my 1995 Jetta. I am wondering which one would be better to get bc I have a kinectic turbo kit with fmic. Any suggestions would be appreciated.
    2. Member Alingarhs's Avatar
      Dec 2nd, 2010
      Denver, CO
      08' GLI, 95' VR6 GTI, 97' VR6 GTI
      08-10-2012 02:55 AM #2
      What about a 268? I hear those are designed for boost.
    3. Member Seamus68's Avatar
      Apr 4th, 2005
      PottsVegas, PA
      84 ABA Jetta, 97 Golf, 84 rabbit 16v, 97 Cherokee
      08-10-2012 01:35 PM #3
      http://forums.vwvortex.com/showthrea...ight=turbo+cam
      This thread has some input to to the question you are inquiring about.
    4. 08-10-2012 02:22 PM #4
      I have actually read that thread, but it doesn't completely give me what I wanted to know. The 260 is designed for use with turbo cars and the 270 doesn't say anything about being designed for turbo cars. That is where my question really is. If the 260 will out perform the 270 in a turbo car I would go for it. But I know in a N/A car the 270 would be better. Seems like most the people in that thread skipped the 260 for the 270. And the reason its between these 2 cams is I can get a great price on these.
      I am leaning towards the 270.
    5. Member deviant12no's Avatar
      Sep 29th, 2003
      Scarborough, Ontario
      98 VW Golf Wolfsburg 1.8T, 01 VW Passat Wagon 1.8T, 95 VW GTI VR6 (rip), 90 VW Jetta Flair2 8V (rip)
      08-10-2012 02:39 PM #5
      I'd compare what cams that TT carries, they have good explanations to what application you want to run, turbo or NA. You may need to change your springs to HD springs, I think you're running an OBD1 setup. Been debating between AT and TT cams for awhile myself..
      yeah.. been on here since '03, but don't talk much s***.. - instagram: whoisjimboslice
      rides: 1998 VW Golf Wolfsburg Edition 1.8t AWP Swap Tornado Red, 2007 VW Golf GTI 2.0t FSI Black Magic Pearl
    6. Member JohnStamos's Avatar
      Feb 3rd, 2010
      A4, A6, Mk3, Shelby, 650x
      08-10-2012 02:58 PM #6
      Need ENTIRE build info, entire intake manifold specs, EVERY turbo detail (What wheels, what turbine housing, what compressor cover), what engine management, and details of any headwork and flow chart if possible to give good Cam advice.
      Other wise, it is all speculation based off others results.
      If you are boosted, you want valve springs with a higher seat pressure no matter what cam you are running. "HD" valve springs, as companies like to market them as, is not a end all of valve springs. If a company markets them to you as "HD" and either provide the spring specs before ordering, or ask you for you cam specs, thats a red flag to go with a different company even IF you can find the springs specs.
    7. 08-10-2012 03:38 PM #7
      John, I am running Kinectic Motorsports MKIII Stage 2 turbo kit. T3/T4 turbocharger (with a .48 AR exhaust housing). As far as more details on the turbo all I know its what Kinectic sends with the kit. The kit uses C2 42# engine management. The engine to my knowledge is completely stock OBD1 ABA internals. The intake manifold is a stock manifold, but I plan on building a custom SRI in the future. I do not have a flow chart available.
      Thanks for all the input guys.
    8. Member SirSpectre's Avatar
      Mar 20th, 2011
      Milwaukee, WI
      2000 Cabrio 2.0 \ 2013 FRS
      08-10-2012 05:18 PM #8
      I think the universal answer is TT 276*. But of the 2 you have listed, 270* all the way.
