Thanks for the reply, I'm not sure what happened. Just going to pull the motor in the next couple days. Timing belt is in tact. Cam to cam chain is tight on the head. It could be stuck. Previous owner said everything was working well. Then just all of a sudden a cyl dropped. Cyl closest to the firewall on the drivers side has about 30psi and it leaks out the intake port.
