Results 1 to 7 of 7
Thread: DIM your DRL's - vagcom
    Nov 20th, 2008
    S. Florida
    11' Tiguan, 10' A4
    08-10-2012 10:05 AM #1
    I am sure this has been discussed before...
    But for those looking to just DIM the DRL's I found it in Byte 24.
    I did have my DRL's turned off, but decided to turn back on for safety reasons.
    I dimmed mine to 55%. Has a nice low radiant glow now. Sorta like the euro driving look.
    You can find it in vcds:
    09 CENT ELEC
    Long Coding Helper
    Byte 24
    Factory had mine originally set at 92%. Just change that value to whatever you wish.
    Cheers
    Sunnin in S. Florida
    Jul 27th, 2007
    Ottawa, Canada
    07 Rabbit, 10 Tiguan, 1928 Chev, 02 Dakota
    08-10-2012 06:37 PM #2
    keep in mind that halogen lights age faster when not at full illumination. The lower you go the faster the ageing.
    Nov 20th, 2008
    S. Florida
    11' Tiguan, 10' A4
    08-10-2012 08:25 PM #3
    Quote Originally Posted by shawng View Post
    Our old Jetta was Dimmed for 3 years and never had a problem... plus bulbs are cheap.
  4. Member
    Oct 9th, 2010
    Atlanta
    08-10-2012 08:36 PM #4
    Its ok to run halogens at less than 60% (as long as not 100% of the time -)
    Those equations are accurate until the point where the halogen cycle stops happening (approximately 80% of design voltage). Running halogen lamps below 80% won't hurt them as long as you don't do it excessively. When you run the lamp back up to 100%, the cycle begins again, and all of the tungsten on the quartz envelope turns back into tungsten bromide, and collects back on the filament. It's only when you run <80% for the majority of the lamp's life that the tungsten buildup greatly reduces output and lamp life.
    Jul 27th, 2007
    Ottawa, Canada
    08-10-2012 09:02 PM #5
    Good to see someone here knows about this. Hat's off magoo
  6. Member
    Mar 22nd, 2012
    Southern California
    2012 Tiguan SEL w/boost gauge and Scangauge
    08-10-2012 11:51 PM #6
    Quote Originally Posted by mymagoo View Post
    What he said... sorry, couldn't resist.
    Jan 6th, 2009
    Pittsburgh, PA
    '11 GTI
    08-14-2012 06:38 PM #7
    I just learned something totally new.
