Results 1 to 24 of 24
Thread: If you could mix/match any parts...
  1. 08-10-2012 12:17 PM #1
    ...and magically make them fit/work, including engine control systems, how would you configure the ultimate internal combustion engine? You can separate this into cylinder classes: 4, 6, 8, etc... and any configuration: inline, boxer, V, W etc....
    For me, I'd choose a V8, specifically the Ford Coyote block. I'd top it off with these heads: www.coatesengine.com running as high a rod/stroke ratio as I could fit in there on a twin turbo system and VAG engine controller for proven aftermarket programability. Using those heads it might be possible to run 11:1 or higher compression on pump gas, even on a turbo motor. I'd have Bosch or whoever does VW's engine systems develop a combined direct and multiport injection system to keep the intake valves clean.
    What would you do?
    Sent from my DROID RAZR using Tapatalk 2
  2. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 01:33 PM #2
    I think I'd take several older engines (pick your favorite) and only modernize a couple of things... Fuel management and metallurgy/production tolerances.
    I could probably safely double the output of my Bug's engine with just those changes while making it live longer. Well OK, I'd use more modern heads (Dual ports didn't start production until '68) and I'd need an oil filter that will screen out more than just boulders and small children.
    You could do similarly with a great many engines from the past. I'd love to see what one could do with the Vega Cosworth engine, the powerplant from my old BMW 2002 and a 240Z with those kinds of changes.
  3. Member McBanagon's Avatar
    Feb 24th, 2010
    Northern part of the Virginia
    Two Vanagons and some old British iron.
    08-10-2012 01:41 PM #3
    I would start with a eight cylinder diesel radial engine, water cool it, then upgrade to DOHC cylinder heads.
  4. 08-10-2012 01:45 PM #4
    Lol, I forgot about radial configuration...
  5. Member Rob Cote's Avatar
    Dec 6th, 2006
    Beverly, MA
    06A3 & 97TJ
    08-10-2012 01:58 PM #5
    I really want to make a diesel VR6.
    When i'm lookin' to get er to spread 'em I usually just throw copious amounts of alcohol at the situation.
  6. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 02:00 PM #6
    Quote Originally Posted by McBanagon View Post
    8 cylinder radial, eh? That's pretty tough to do.
  7. 08-10-2012 02:01 PM #7
    How 'bout a Hemi with a blower in a Prius. With a shaker hood for effect.
    Jan 25th, 2010
    Dayton, OH
    2008 GTI Tornado Red
    08-10-2012 02:11 PM #8
    How about a 8 cyl boxer Quad turbo (GT45R with the 40R turbine), Midengined, two seater with AWD. Oh and keep it a 6spd
    Think a slightly longer Cayman with AWD, 2 more cylinders and a bunch of turbo's
  9. Member McBanagon's Avatar
    Feb 24th, 2010
    08-10-2012 02:13 PM #9
    Quote Originally Posted by Air and water do mix View Post
    What did you think I was going to do - a six-cylinder, 12 cam, water-cooled, diesel radial?
    No one wants that
    Everyone knows the six is the embarrassment of the DOHC diesel radial community, and it only exists for people who can't afford the eight.
  10. Member
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    08-10-2012 02:14 PM #10
    What did you think I was going to do, a six-cylinder, 12 cam, water-cooled, diesel radial?
    No one wants that.
    4-stroke radial engines require an odd number of cylinders
    Call To Order Pizza But Too Shy To Answer The Door When It Arrives Crew
  11. Member curvedinfinity's Avatar
    Oct 11th, 2004
    Highway to the danger zone
    F14 Tomcat
    08-10-2012 02:20 PM #11
    Half rotate star 12 running on hydrogen
    Personal website with contacts: http://curvedinfinity.com
    Shenandoah hot lap 1:46.92: http://www.youtube.com/watch?v=RmYq3mBbwPg
  12. Member McBanagon's Avatar
    Feb 24th, 2010
    08-10-2012 02:22 PM #12
    Quote Originally Posted by FissionMailed View Post
    Everyone knows that, that's why this one is a 3-stroke.
    I would have gone 2-stroke, but I was too busy dreaming of 16 camshafts.
  13. 08-10-2012 02:22 PM #13
    This
    in this
    2009 Mazda 6 GS V6
    2008 Suzuki Hayabusa
  14. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 02:26 PM #14
    I figured he already knew that but was simply being... Well, McBanagon.
    Like this, see?
  15. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 02:27 PM #15
    Quote Originally Posted by karl_1052 View Post
    This
    in this
    You only need 1 F1 engine for the Mini. Duh.
  16. Member
    May 26th, 2006
    Chattaboogie, TN
    2011 GTI #yolo
    08-10-2012 02:48 PM #16
    It became pretty clear to me after I quoted his second post that he was joking, but I just felt I'd throw the odd-numbered-cylinders fact out there, since I wasn't sure if that part was a joke or not
  17. Member tragik's Avatar
    Jul 10th, 2005
    SNH/North Ma
    2010 jetta tdi
    08-10-2012 02:55 PM #17
    twin turbo LS7 TDI
    Crammed into an AWD RX7
  18. Member stascom's Avatar
    Sep 12th, 2009
    So. Oregon
    a Nissan
    08-10-2012 03:01 PM #18
    7-cylinder
  19. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 03:08 PM #19
    Well, there's that and I like to ask questions that I could find the answer to on-line. That way the information is here in the thread for anyone to read. If I simply looked it up for myself, then others wouldn't have the benefit of answers to questions they might not ask. You know, an ongoing discussion.
    If there's doubt, it's probably safe to say that McBanagon is having fun at any given time. It's also safe to say he's had me laughing out loud on much more than one occasion.
  20. Member McBanagon's Avatar
    Feb 24th, 2010
    08-10-2012 03:10 PM #20
    Quote Originally Posted by stascom View Post
    7-cylinder
    Well sure, THAT one is.. I haven't made mine yet, so that's the only configuration I could find.
    You know, I might be able to make the seven work, but only if I can source one Honda NR750 piston.
  21. Member Air and water do mix's Avatar
    Aug 5th, 2004
    Southern Indiana
    08-10-2012 03:12 PM #21
    Dammit! I nearly shot Dr. Pepper out of my nose!
    See folks? This is what I'm talking about. How the hell do you come up with some of these?
  22. 08-10-2012 03:19 PM #22
    LMAO now....
  23. Member McBanagon's Avatar
    Feb 24th, 2010
    08-11-2012 02:28 PM #23
    Final design:
    • Four stroke, seven cylinder radial (less complicated than the three-stroke 8)
    • Oval pistons/quatrovalve
    • Diesel (plans for future bio-diesel conversion kit)
    • DOHC (14 cams in all)
    • Quattrovalve
    • Water-cooled
    Since it's water-cooled, it could be placed anywhere. Mid, rear, front engined layouts are possible (plans for roof-mount are currently being engineered) It can be mounted transversely, longitudinally, or even upside down. The engine will be a perfect candidate for conversions, as the rotation will can be CW or CCW due to the flywheel being mounted on either side of the crankshaft.
    RWD, obviously, but it probably won't come to the US.
    Still working on trying to figure out how to make the timing chain service simple, since 58 feet of it will stretch enough to require replacing it at every oil change.
  24. Member stascom's Avatar
    Sep 12th, 2009
    So. Oregon
    a Nissan
    08-11-2012 04:52 PM #24
    epic engine
    exhaust-aspirated hepta-turbo setup with three superchargers, right?
