#1
looking at new spark plugs for my girls 02 cabrio 3.5 all the threads that tell you the NGK number the pictures are down or missing cant find that much info on this
also looking at wires too any suggestions?
thanx in advance
#2
#3
Cause every autozone and advance autoparts store around me is a bunch of idiots, so I like to make it as brainless as possible for them
Any suggestions on plug wires looking at aftermarket ones like euro sport but not sure if its even worth it, I'm not building the motor up or nething but a stronger spark is always better
Sent from my T-Mobile G2 using Tapatalk 2
#4
Bosch wires, not part store brand. With a stock ignition system, there is no benefit to "upgrading" the wires. Just get the Bosch replacement set. I have seen many made-in-China parts-store-brand wire sets arc right out of the box, so stick with Bosch, it's worth the extra couple bucks.
FWIW, I usually use Bosch Super plugs for ABA. NGK may also be OE, those will work fine as well.
Just a suggestion...if you're just doing maintenance, it's a good idea to replace the cap and rotor at the same time as the plugs and wires.
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#5
#6
Really, cause Bosch was an OEM plug for VW much longer than NGK has been. Stay away from any multiple prong plug and you'll be fine. I generally get any "basic" plug and they work just fine, no matter the brand. You can go with a platinum or iridium plug for longer replacement intervals. The main thing on any plug is to have it gapped to the correct spec and have the correct heat range for the application.
FS:Sunroof Deflector
#7
The Professor
Melbourne, FL
92 Corrado OBD2 ABA Powered by MS3Pro
M & L EFI Performance
#8
Truth.
Bosch Platnium +2 and +4 plugs generally suck, with a few exceptions where they are OE. Bosch Super are regular copper plugs, and good ones.
Bosch makes the OE wires for ABA, and they also make many components for VW (from plugs to ECU's and everything in between) and always have as far as I know. Where are you reading bad about them? Keep in mind, there are many made-in-China "Bosch" knockoffs, beware of those.
1998 GTI 2.0
1993 Jeep ZJ 4.0
World Automotive
#9
im at wrk now or i would site the other topics that bring bosch down, did a simple search for spark plugs and found a lot of negative information aganist them
#10
