Results 1 to 3 of 3
Thread: In tank fuel pump?
  1. Member azunderg's Avatar
    Apr 29th, 2009
    85006 | Garfield District
    MK5 GTI|Fixie|Light Rail
    08-10-2012 01:03 PM #1
    Is it common for these fuel pumps to go out with the 2.0T FSI motor?
    Phoenix DMZ
    The Ghetto
    New South | Neuspeed | ECS | Optima
    Sep 23rd, 2009
    Dallas, TX
    2007 Audi A3 2.0T
    08-10-2012 02:01 PM #2
    Quote Originally Posted by azunderg View Post
    The only common issue I know of is the thrust sensor on the high pressure fuel pump (mounted on the engine) going bad, which causes the in-tank pump to run at 100% duty cycle and overheat, eventually causing fuel cuts during extended driving and sometimes killing the pump entirely. I had to replace my thrust sensor and in-tank pump because of this exact scenario. I believe there has been a warranty extension issued for the low pressure sensor failure, so you might check into that.
  3. Member azunderg's Avatar
    Apr 29th, 2009
    08-10-2012 02:30 PM #3
    Quote Originally Posted by TBomb View Post
    I wish paid $115 to the dealer becaue I thought it would be cam follower related. The repair they wanted to perform was for the module and rear pump...
    Phoenix DMZ
    The Ghetto
