Results 1 to 5 of 5
Thread: Coolant leak...bad
    Oct 5th, 2011
    2001 GTI 1.8t
    08-10-2012 01:17 PM #1
    I've been slowly loosing coolant somewhere but so I've been putting distilled water on it till I could get around to it. The car has been sitting for a day or day because the diverter valve broke and I'm waiting on a new one. I went out to the car to get something out of it and just decided to take a look, well the coolant tank wask completely empty and under the car there's a steady drip of water right under the timing belt area, is it time for a new timing belt and water pump?
  2. 08-10-2012 01:21 PM #2
    Quote Originally Posted by GTIRyanB View Post
    Most common leak would be the thermostat cover (housing). Check behind the timing belt cover for leaks @ the water pump, then check the thermostat housing @ the block.
    "I am for truth, no matter who tells it. I'm for Justice, no matter who it is for or against. I'm a human being, first and foremost, and as such I'm for whoever and whatever benefits humanity as a whole" - Malcom X
    Jun 15th, 2011
    Kitchener, Ontario
    1999 Beetle TDI, 2002 GTI 1.8T, 1999.5 GTI VR6
    08-10-2012 02:26 PM #3
    lay cardboard under the car to see what side the drips are comming from ?
    i had a leak from my rad once, another from my secondary coolant pump.
    goodluck
  4. Member 3Dachs's Avatar
    May 21st, 2003
    Town of the Cow, TX
    IY 20th Ann. GTI #657 Original Owner
    08-10-2012 04:11 PM #4
    I just replaced my water pump and timing belt due to a leaking water pump. Mine leaked any time the car ran. It didn't have to get hot and build pressure first. Once I pulled the water pump out, it looked like the o-ring was the culprit, but I wasn't going to replace just the o-ring on a water pump with 55k miles on it.
    Oct 5th, 2011
    2001 GTI 1.8t
    08-10-2012 07:19 PM #5
    I'm just going to get everything replaced (belt, water pump, thermostat, tensioner, etc.) because I bought the car used and I'm about to hit 186,000 and I have no idea when it was done last so it could probably use it.
