Make sure everything is pluuged in, as I see a connector out in the photo.
Then, are you trying to bleed the brakes by the old pump-then-bleed method?
If so, don't. Power bleeding is a must on these cars, just get/rent a power bleeder,
I paid abour $50 for mine - makes the job A LOT easier, and does the job very well.
Now i see a new problem I see some smoke coming from the motor on the master cylinder assy I am not sure if is because the motor is overheating or is it because it is fried. I still have not been able to bleed the rear brakes. all help will be great. thanks.
