VWVortex.com - AFE Scorcher
    Results 1 to 5 of 5
    Thread: AFE Scorcher
      May 23rd, 2008
      Richmond, VA
      2013/VW/Passat TDI SEL
      08-10-2012 05:24 PM #1
      Has anybody tried the AFE Scorcher module on their Passat. They say it fits and works on the TDI. Just curious?
      Sent from my iPad using Tapatalk HD
      Apr 21st, 2012
      Millersville, MD
      2012 Passat TDI, 2005 Ford F-250 6.0 diesel, 5 2015 Lincoln MKZ Hybrid, 2007 Artitic Fox 5th Wheel
      08-10-2012 05:55 PM #2
      I can't find it listed for the Passat TDI....... but as I'm under a 7 year warranty, ain't interested either!
      2012 Passat SE TDI NAV
      2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
      2007 Arctic Fox 30' Fifth Wheel
      May 23rd, 2008
      Richmond, VA
      08-10-2012 07:36 PM #3
      When I go to afepower.com, and select Diesel, the VW Diesel, 2012, Passat, 2.0L, I get the Scorcher and the intake as options...
      Just curious if anybody has tried it or know somebody who has...
      -Ray
    4. 08-11-2012 01:28 AM #4
      The dyno sheet for the intake is for an '09 jetta tdi so not really sure what the gains would be on the B7. Under the Scorcher once you filter for the B7 passat then go to the product the application shows Golf on the item? I would call them they maybe assuming its the same engine as the jetta/golf but as APR has stated they are several versions of ECU software version being used on the 2.0 tdi CR and why APR chip is still in development for some of them.
      Quote: Currently we are extracting and flashing ECU’s with the 1796 processor. However, vehicles with the 1797 ECU found in select new vehicles are still in development."
      However they are grouping Audi/VW CR engines together and not being specific which platform i.e. B7 or not??
      May 23rd, 2008
      Richmond, VA
      08-11-2012 12:26 PM #5
      Good points George! I'll call them on Monday.
