Results 1 to 4 of 4
Thread: Torque converter for an '82 ,1.6 L Diesel
  1. 08-10-2012 06:39 PM #1
    I have an '82 ,1.6 L diesel out of a Rabbit pickup that I want to put in a GEO Tracker. The Tracker has a Geo A/T and its torque converter is not compatible with the power output of a diesel. Is there a VW diesel with an A/T that I can use ,either as a whole unit or just its torque converter ? If there is I will try and adapt that or, if not, I will have to replace the A/T with a GEO 5 speed M/T, which I know will work. Thank you, Ken
  2. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    08-10-2012 11:14 PM #2
    There were auto mk1 diesels. Not sure about mk2's.
    Keep in mind too, even if you go with a 5-speed, you need the correct gearing to make it work well with a diesel. Yes, a gasser manual will work, but the gearing will be off and you'll be in high RPMs at highway speeds more than likely.
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  3. 08-13-2012 04:52 PM #3
    I'm not familiar with the MARK series . Ken
  4. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    08-13-2012 05:05 PM #4
    Year ranges. There are forums for each below. Mk1 is through '84. Mk2 is '85-'92 I think.
