Results 1 to 3 of 3
Thread: First Vag Com Scan have a few faults, need advice
  1. 08-10-2012 09:13 PM #1
    I got a few fault codes... Seems like it is all related to the ignition switch. Is this common? There are no symptoms other than the fault code.
    The tire pressure fault code 02801, don't know what that means.... It has been very hot here and had tire changed recently. Thanks
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 085 G HW: 5K0 937 085
    Component: BCM PQ35 B++ 111 0128
    Revision: BI111001
    Coding: 2D380E1A902F3EC480080081400000C401000086535D856064 8020000000
    Shop #: WSC 00066 000 00000
    VCID: 377D93AF8656A51
    Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 12021 21 0512
    Coding: 009795
    1 Fault Found:
    00883 - Ignition Switch (D) Terminal S
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 144
    Mileage: 78788 km
    Time Indication: 0
    Date: 2026.14.24
    Time: 16:16:23
    Freeze Frame:
    Term 15 On
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
    Component: J0527 056 0111
    Coding: 0001532
    VCID: 76E35EAB01DC1C9
    Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Shop #: WSC 00000
    4 Faults Found:
    00576 - Terminal 15
    012 - Electrical Fault in Circuit - Intermittent
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
    Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
    Component: RDK 111 0821
    Coding: 018705
    1 Fault Found:
    02801 - Hard Warning
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    Text: 3446573155
    Pressure: 0.10 bar
    Pressure: 2.40 bar
    Temperature: 38.0°C
    Text: A0
    Speed: 0.0 km/h
    Mar 3rd, 2012
    Lyndhurst, NJ
    2006 Passat 2.0T
    08-10-2012 09:16 PM #2
    Quote Originally Posted by gmcjetpilot View Post
    Revision: BI111001
    Coding: 009795
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 144
    Mileage: 78788 km
    Time Indication: 0
    Date: 2026.14.24
    Time: 16:16:23
    Freeze Frame:
    Term 15 On
    Voltage: 11.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Coding: 0001532
    Coding: 00000130
    Shop #: WSC 00000
    4 Faults Found:
    00576 - Terminal 15
    Coding: 018705
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    Text: 3446573155
    Pressure: 0.10 bar
    Pressure: 2.40 bar
    Temperature: 38.0°C
    Text: A0
    Speed: 0.0 km/h
    Being it's intermittent, clear them and see if they come back. Most likely nothing to worry about.
  3. 08-10-2012 10:46 PM #3
    I disagree, absolutely something to worry about.
    Verify the ignition switch isn't burning down and check all connections.
    Next time please post a complete auto-scan.
    Fire Fire Fire.
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
