Results 1 to 9 of 9
Thread: TDI Fuel Additives
  1. 08-10-2012 10:30 PM #1
    I just rec'd. a "kit" in the mail that came from VW. A yellow sticker for the fueling openig warning of low sulfer fuel only. I use the Gulf since it has a good feel and 45 cetane where most offer 40.
    Do any of you use a fuel additive? I know VW warns against using this highly BUT then they actually sell one called Stanodyne. It seems a bit contradictory.
    Do any of you use any of these products at all? On a trip since you don't know what you're getting or all the time?
    Thanks -
  2. Member 2011VWTDI's Avatar
    Jul 24th, 2011
    Vienna, VA
    2011 VW TDI, DSG, Xenon, Dynaudio
    08-10-2012 11:17 PM #2
    nope
  3. Member chrisMk6TDi's Avatar
    Dec 10th, 2011
    Central MA.
    2011 Golf TDI
    08-11-2012 04:46 PM #3
    Stanadyne is the only additive approved by VW. it's not really worth it IMO however as I never noticed a difference wih/without.
    '11 TDI Reflex Silver/DSG/AWE dual catback
  4. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    08-11-2012 05:03 PM #4
    AVOID
  5. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    08-11-2012 05:06 PM #5
    I do use B5 biodiesel, though, because I am a gullible treehugger.
    Pro: higher lubricity for the fuel pumps. Con: requires strict adherence to the prescribed 10k oil change interval to prevent oil dilution.
  6. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    08-12-2012 09:02 AM #6
    Been using 4oz of DieselKleen since day one and 40,000k + later the car is going strong with zero issues. Good power, engine is smoother and a tad more quieter as well. I'm getting about 47mpg average on my commutes.
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  7. Senior Member feels_road's Avatar
    Jan 27th, 2005
    East Bay Area
    2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
    08-12-2012 12:22 PM #7
    I don't use any additive - but CA has good Diesel fuel with reasonably high cetane rating (42-43?), and supposedly most providers add some BioDiesel (1+%?). I stick with Chevron.
    Aung San Suu Kyi
  8. 08-13-2012 08:25 PM #8
    You went to great lengths as I recall with your car. Every little to large modification there seemed to be! I was really impressed the way you tracked it and all. What's the deal with the info. I just got indicating that nothing extra, NOT even biofuel should be used in these TDIs?
    I'm a little taken back that they say nothing else but low sulfur diesel but then sell stanodyne. Have you any info. about this including the biodiesel/stanodyne?
    Thanx - Gonna have to see what you've done to your car since last year -
  9. Senior Member feels_road's Avatar
    Jan 27th, 2005
    East Bay Area
    08-13-2012 10:45 PM #9
    Up to 5% BioDiesel is fine as per VW specs. Up to 10% is likely OK if you do more frequent oil changes (e.g., have oil analysis done and likely need to change every 5,000 miles or so, since BioDiesel condenses on the cylinder walls, gets scraped into the engine oil, and dilutes it). An even higher percentage of BioDiesel is likely detrimental to the fuel pump and injectors, due to its much higher viscosity.
    I don't know of any connection between Stanadyne and VW.
    I don't know of any benefit of additives to CR TDI engines other than a few percent (1-2%) BioDiesel to guarantee sufficient lubricity.
    Diesel should be winterized from the refinery where and when applicable.
    Aung San Suu Kyi
