#1
So i was on my way home from work when my clutch pedal decided to stop letting me change gear. I changed both the master and the slave cylinders to try to fix the problem and bled it multiple times with a power bleeder and although the clutch pedal feels fine and has plenty of pressure, i still cant get into any gear. I even dropped the trans to check the clutch, throw out bearing and release lever, all of which were fine and have about 50k miles on them. Its been three weeks of removing replacing and rebleeding everything and i am at a total loss. I have no clue what else i should try. If anyone has a clue please chime in i really need my car back paying for gas driving a suburban 60 miles + a day is killing my wallet. What a headache....
Silver 03 GTI 1.8t: unitronic stage 1+, cai, 3" Catless Downpipe, 2.5" Catback, TIP, 2.0t coilpacks w/spacers, forge short shifter and DV, eurojet discarge pipe kit, VR6 Clutch w/14lb smfw, zimmerman front cross drilled rotors, fk cup kit...02M swap and H&R Coilovers coming soon...
