Results 1 to 6 of 6
Thread: Corrado fuel tank swap
  1. 08-11-2012 10:53 AM #1
    Hello,
    I have a G60 car . What I like to do is put the The larger 18 gallon fuel tank for more range. I would like someone who has done this give some advice on this. Is there other options out there that will also work.........Thanks for your time.............
  2. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    08-11-2012 01:00 PM #2
    To do what you are asking would require you to weld in a VR6 trunk Floor pan.
    Not very feasible. Doable? Sure, anything is...
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  3. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    08-11-2012 01:15 PM #3
    Quote Originally Posted by sdezego View Post
    Or just buy a decent SLC shell and put all of your G60 stuff in it.
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
    Sandy Linfert 11/4/1991 - 5/13/2013
  4. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    08-20-2012 10:17 PM #4
    I know for a fact VR6 tanks do NOT fit G60 bodys.
    Your only pratical option is a fuel cell.
    500HP 1990 Cowrado
    Have a great Orwellian Day
  5. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    A6 TDI Quattro wagon, A4 V8 Quattro racecar
    08-21-2012 05:24 PM #5
    If you want more range swap a TDI in to it
    Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
  6. Member hallkbrd's Avatar
    Apr 8th, 2000
    Oklahoma
    '05 1.8T Corrado
    05-12-2013 08:42 AM #6
    Yep - you have to cut out the floor pan.
    It sits about 1.5 inches higher than the G60 fuel tank - so the floor has to go.
    A life frittered away disgusts God; he loves those who run straight for the finish line.
    Never Ending 1.8T Corrado Project
