Results 1 to 12 of 12
Thread: Hi, 3.2 engine makes really high pitch whining noise at cold start
  1. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-11-2012 02:06 PM #1
    Hi, has anyone encounter this problem? Only during the first 10 ~ 15 secs or so after starting the car, then it goes away. What could be the cause?
    Thanks for your time.
    Jack
    2007 3.2Q
  2. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    2003 Silverstone GTI 1.8t(Gone), 2006 Brilliant Red Audi A3 3.2Q
    08-11-2012 05:36 PM #2
    Sounds like the secondary air pump.
    Mods:Unitronics Stage 1+ | UM DSG Tune | Magnaflow Catback | HPA SHS Coilovers | MODSHACK VTDA intake
    VRSociety #172
    Quote Originally Posted by Boost112 View Post
    Interests:Food being shoved in hot chicks faces.... and other stuff....
  3. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-11-2012 06:11 PM #3
    would you happen to know if is a simple DIY job? Thanks
    Sent from my SGH-I747M using Tapatalk
  4. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    08-11-2012 06:23 PM #4
    If you can find the fuse for it and pull it you can see if it stops making that noise at start up. Sorry don't have a DIY. Do a search for SAI delete. It stands for Secondary Air Injection
    VRSociety #172
  5. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-11-2012 06:33 PM #5
    awesome, thanks for the info.
  6. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    08-11-2012 06:54 PM #6
    No problem. Post back with results.
    VRSociety #172
  7. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-13-2012 02:23 AM #7
    Just had a chance to look under the hood, am I missing something from the connector on the left side of the stick air box?? I didn't remember that it connects to nothing?
    Thanks.
    3.2Q
  8. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    08-13-2012 06:46 AM #8
    That's normal. Nothing connects there
    VRSociety #172
  9. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-13-2012 04:49 PM #9
    It turns out that there's one little house from the top that came loose, fitted it back in but seems little loose. That's how this fix the issue :-)
    Thanks.
  10. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    08-13-2012 06:55 PM #10
    Mind if you post a pic of the hose you're talking about. Just curious
    VRSociety #172
  11. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-13-2012 07:48 PM #11
    Sure, waiting for the ECS dogbone insert, will snap a pic at the same time, cheers.
    Jack
  12. Junior Member
    Mar 18th, 2007
    Vancouver, BC
    08-20-2012 08:10 PM #12
    The little 90° connector on the left fell off. It hasn't been making noise after reconnecting. Seems on the loose side, maybe need to tighten with a metal clamp or zip tie.
    Cheers.
    Jack.
