(semi) Random Thoughts:
- Coolant Expansion Tanks, Caps, and Fittings can leak, but not be noticeable when unpressurized.
- Having approx 15psi in the Coolant System is necessary tot e design to operate correctly.
- Heater Core must have coolant flowing through it during bubble purging, air burping, re-filling procedures.
It is , ness, in fact counter-productive to turn on the HVAC FAN during this, you just want the heater's Coolant Valve OPEN.
Note: based on the A2's I campaigned, I always had coolant flowing through the little hose and into the Coolant Exp Bottle, when the Engine was running. This may not be the case w/ A1 chassis 16vs, I wouldn't mind somebody touching on this-
Does a properly working Scirocco 16v have constant coolant flow into and through the Expansion Tank when the Motor is Running?
I'm not sure what you mean by that, obviously it shouldn't run all the time. Or do you mean that it doesn't come on reliably when the car gets too hot?
) if you approach the problem methodically.
